Thread: Passate B5.5 Estate Rear Light Removal
  1. Passate B5.5 Estate Rear Light Removal
    Jul 2007
    Co Durham
    How on earth are you supposed to gain access to the nearside rear light assembly of a Passat Estate (B5,5, 2001) to change bulbs? The four nuts holding the lamp unit in are either behind the trim panel or the plastic rack holding the CD Player, Warning Triangle etc. The bolts holding this rack in place are mainly behind the trim panel! Anybody done this before? I've seen various other posts on the subject which make it sound easier than it is - am I missing something? Thanks
  2. Re: Passate B5.5 Estate Rear Light Removal
    Jun 2006
    UK, Mids
    All you do is open the upholstery flap, squeeze the black plastic tabs and the black plastic bulb holder is withdrawn. I think there are two of three tabs to squeeze/unclip. No bolts need undoing, it should only take a minute, use a torch, there may also be a cable connector to unclip and pull out. The firs time may take a while as you don't want to break anything, after that you can do it blindfolded.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Passate B5.5 Estate Rear Light Removal
    4dogbob Guest
    nothings ever easy is it
    it took me an age just to get at the sidelight bulbs, i swear vw design these cars to be as awkward as possible to us simpletons lol
  1. Estate rear light removal
    By LeFrog in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-03-2013, 04:17 PM
  2. B6 Estate multiple Trim removal
    Last Post: 04-04-2010, 07:20 PM
  3. HLP PLS - Removing rear light on Estate 2001 'Y'
    By fraz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2008, 03:31 PM
  4. 2001 Passat Estate rear luggage light
    By Almac1903 in forum Passat - Archive Topics
    Last Post: 24-11-2007, 05:03 PM
  5. 130 SPORT ESTATE. Water in REAR LH light well!
    By EddyStone in forum Passat - Archive Topics
    Last Post: 19-03-2006, 06:32 PM
