Thread: S4/S-line external door plastic trim removal?
  1. S4/S-line external door plastic trim removal?
    May 2008
    does anyone know if it is easy to remove the body work trim at the bottom the doors found on the S-lines and S4's??
    without breaking it of course
    thanks in advance
  2. Re: S4/S-line external door plastic trim removal?
    Dec 2007
    open the doors you will see a screw at each end ! 2 screws per trim
    remove the screws and with door open slide the trim out slide to the back of the car
  1. Door Trim Removal Help???
    By jhonne in forum Touran - Sharan - Caravelle
    Last Post: 15-05-2013, 09:21 PM
  2. A4 1.8T Cab 2003 door trim removal
    By Steve Cassidy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2008, 06:04 PM
  3. Removing plastic trim on sill of the door
    By sheka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 08:47 AM
  4. Door trim removal
    By trebor54 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-07-2007, 10:50 AM
  5. A4 B5 Avante door trim removal
    By deano2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-06-2007, 08:52 PM
