Thread: Sharan MOT failure
  1. Sharan MOT failure
    Jun 2007
    Bristol
    My sharan failed mot today , on :
    1.Hole in catalic
    2.Immsions ( due to hole in cat )
    3.Offise rear coil spring incomplete
    GFS do the the cat for £79 and the spring for £59
    Now the rear spring is proably DIY do-able , but the cat , without raising im not so sure ,
    Has anyone changed a cat DIY without raising the car ??
    Local exhaust and tyres place wants £185 fully fitted to do the cat , is it a case of biting the bullet and letting them fit it ?
    Advice welcome
    MK5 Golf TDI 2.0ltr GT Sport in Black
  2. Re: Sharan MOT failure
    Apr 2007
    Lancashire
    Hi Paul, I think that if you unbolt the downpipe from the turbo, then go under the car and loosen the clamp from the CAT to the sleeve fit mid section, after removing it from the exhaust hangers you 'may' possibly be able to remove the CAT & flexi-pipe through the engine bay.
    Then it is easy to remove the CAT from the front pipe.
    Be careful not to bend the flexi-pipe.
  3. Re: Sharan MOT failure
    Jun 2007
    Bristol
    ini thx reply , m8
    Ive been out and under , sure enough there is a lovely hole about 5mm wide in my cat ,
    Will this cause it to fail emissions then ?? , i dam hope so lol ,
    Anyway i can see all bolts , the U clamp holding to the center section comes off no problem , but the front 3 bolts holding the cat to the down pipe are really corroded , i can t even get a socket on the head of one its so bad, and lying on your back is difficult too !!!
    Think I need a hoist , with a hoist its a 20 min job , dam !!!!
    I will try a few local garage who will fit , if i supply the part ,, it cant be no more than 1hr labour max , at say £45ph thats still only £125 as opposed to £185
  4. Re: Sharan MOT failure
    Apr 2007
    Lancashire
    Dont attempt the bolts when the CAT is on the car.
    If possible, remove the downpipe and CAT as one section, then it is much easier to free the CAT.
  5. Re: Sharan MOT failure
    Jun 2007
    Bristol
    its gunna have to go into my local non dealer garage i think ini m8 , hes got a oxy/accatalene burner if needed
    thx for your help
  6. Re: Sharan MOT failure
    Jun 2007
    Bristol
    ive removed all corroded bolts ,
    Used a angle grinder on the bolt head , then tapped out the bolts
    replaced with new , until new cat arrives , so should be able to fit on my drive , fingers crossed
    Ini ive pm,ed you also m8
  7. Re: Sharan MOT failure
    Jun 2007
    Bristol
    Ini ..... thx for all your help and advice m8
    My sharan has just passed its MOT with flying colours !!
    the emissions were very low indeed with a new cat fitted !!!
    Total cost £110 incl rear spring from EPC
    have a beer on me tonight ini
  1. sharan instrument failure
    By aerobobcat in forum Touran - Sharan - Caravelle
    Last Post: 13-06-2008, 09:18 AM
  2. MOT Failure
    By saunders1587 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2008, 09:57 PM
  3. MFD failure
    By Mav2006 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-04-2008, 01:14 PM
  4. Possible ecu failure? V6 30v 2.8
    By JodyV6 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2007, 04:47 PM
  5. MOT Failure!!!!!!!
    By atell40 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2007, 12:48 PM
