Thread: sharan,05,90bhp ,diesel, drivers electric window problem
Results 1 to 8 of 8
  1. sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    window stopped working a few weeks ago, the emergency lights flashed when i tried to open or close window, but by opening the door a few inches the glass moved perfectly. it might be ok for a few days then.
    I suspected the electrical conns. going to the door but i have done no checks yet. Today it has stopped working and i am unable to get it to move with the door in various positions, the emergency flashers light when the switch is put to the open or close positions,--luckily the window is stuck closed
    any help/ideas would be appreciated -thanks
    ps: i hope i am posting to correct forum!
  2. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    Dorset
    Sounds like a loose connection at the door hinge area. Unplug the door then loosen the rubber grommet where it emerges from the 'A' pillar, and inspect the wiring there.
  3. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    Quote Originally Posted by Funky Ferret View Post
    thanks for reply,
    have unscrewed connection to pillar last weekend- all conns appeared ok , no damage obvious.
    will do further checks this weekend, remove door card and check with meter for shorts etc
    window still not working, all emergency lights flash with windows switch!
    rgds
    2mtec
  4. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    Had a simlar proplem...broken/loose connection....heres a tip....when you have found the connection that is at fault, disconnect the battery, repair it then re connect the battery.
    it seems the system gets confussed where the window is
  5. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    Quote Originally Posted by 3dogs View Post
    tks for help 3dogs
    where was the broken/loose conn?
    tks
    2mtec
  6. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    Mine was the brown (live) connection in the rubber gaiter in the door jam
  7. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    tks 3dogs
    will check on that line again,
    rgds
    2mtec
  8. Re: sharan,05,90bhp ,diesel, drivers electric window problem
    May 2008
    thanks funky ferret and 3dogs for help.
    got it sorted -had to do major disassembly-remove door card and speaker etc.--firstly disconnect / unscrew main connection from pillar for safety.
    broken thick brown and thin green wires- severed at door end of gaiter.
    split grab handle and lifted switch asm. to expose 3x10 mm screws-removed these and lifted complete panel up and out-
    removed a few electrical conns.
    gaiter at door end was difficult to remove -held in by three barbed clips.
    after wire repairs and reassembley all worked ok.
    rgds
    2mtec
  1. Sharan nsf electric window problem
    By colinwdick in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2008, 11:51 PM
  2. a4 drivers door electric window
    By andy-cad in forum Chat - Anything with wheels
    Last Post: 27-10-2007, 10:17 PM
  3. Drivers door electric window problems
    By Dken in forum Golf MK5 - 2004 - 2009
    Last Post: 29-09-2007, 08:10 PM
  4. Drivers Side Electric Window not working
    By philpg00 in forum Touran - Sharan - Caravelle
    Last Post: 24-04-2007, 01:37 PM
  5. drivers side electric window fault
    By alanled in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2007, 04:22 PM
