Thread: Passat 1.9tdi sport vacum pump
Results 1 to 9 of 9
  1. Cool Passat 1.9tdi sport vacum pump
    Dec 2006
    hi Everyone,
    i have a 99 TDI 110 passat sport with 54,000 miles on, cople of days ago a ticking noise started coming from the glove box, my mechanic told me it was a vacum pump which is a common fault on these. My question is what does it do 7 how much do they cost?
    thanks
    london/ UK
    Does the car has climate control ? As far as i know, the vacuum pump is close to the engine...you may hear a climatronic relay...from a air flow control/positioning flap.
    Dec 2006
    Quote Originally Posted by adamss24 View Post
    Yes sorry forgot to say that it does have a climate system, also have been told that the fan for the system also needs changing cost of which is £139.00 ouch!!!!!!!!
    london/ UK
    Quote Originally Posted by hotaero View Post
    What is wrong with the existing fan ? Is som'thing not working as it should with the A/C ? Did they pulled any diagnostic faults off the car and can you post the fault codes on the forum ? Thanks.
    Dec 2006
    No nothing is wrong as yet but i have been told that the fan needs changing as it will go and as they would have to take out the dashboard to get to the vacum pump they might as well change the fan as it will cost more money later on to change !
    london/ UK
    I think they just need to make more money from you...i think the vacuum accumulator on your car its under the front passenger wing...follow the small diameter rubber hoses from the turbo and see where the vacuum accumulator is(should look like a black plastic ball), the pump is on the engine as far as i know...but get a second opinion as i might be wrong ! Why fix som'thing if its not brocken ?! Good luck.
    Dec 2006
    Cheers will do !
    Dec 2006
    Hi again, just spoke to the garage they are saying it is not the accumulater it is a motor that controls the heater vents that needs changing !
    Dec 2006
    Hello and Welcome to the Forum!!
    You seem to have got a good response already... one little thing to add is please post in the Passat forum https://www.vwaudiforum.co.uk/forum/f...splay.php?f=11 where your post will get more views and a increased chance of a resolve.
    Many Thanks
    RicKT
  1. New Passat - SE or Sport
    By ak77 in forum Passat - Archive Topics
    Last Post: 21-03-2007, 10:51 AM
  2. AUDI A4 Avant 1.9TDi Sport
    By Dazbroker in forum Audi A4 - Archive Topics
    Last Post: 17-02-2007, 12:09 AM
  3. Passat 1.9 tdi sport
    By dickturpin in forum Passat - Archive Topics
    Last Post: 31-10-2006, 02:38 PM
  4. 1.9TDi 130 Sport Exhaust/Heat shield noise
    By landon in forum Passat - Archive Topics
    Last Post: 14-08-2006, 07:56 PM
  5. 2003 PASSAT 130 SPORT
    By ALED O in forum Chat - Completely Off Topic
    Last Post: 13-03-2006, 10:02 PM
