Re: Odd size of cigarette lighter in front?? –
03-09-2008,05:30 PM
Some plug-in accessories have interchangeable tips where they pick up the centre +12v of the socket. I have had cases where the power is there but the 3rd party plug just wont pick up the centre connection, or when it feels like it. It tends to be the 3rd party non-official devices that I have had problems with - if possible stay with manufacturers official power unit.
Check the power at the front cig socket with a +12v test lamp or DVM (Digital Volt Meter). This will confirm the fuse is not blown. If the voltage is there it's the accesory power device which is not 100% compatible. Note the outer shell will be connected to the chassis, i.e. Ground or 0v, and the centre tip seen at the bottom of the plg will be +12v. (Be careful not to short the centre to the shell using exposed wires or test probes.)
The front cig lighter fuse is rated at 15A on Fuse 33 - plenty of power for a phone charger!!
My +12v Halfords Tyre Inflator works intermittently and was a tight fit, yet TomTom and Snooper worked 100% without any problems in the same socket.
A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
