Thread: Changing headlight bulbs
Results 1 to 10 of 14
  1. Changing headlight bulbs
    Has anyone any experience of changing the main beam bulbs in the Passat?
    According to the manual it requires a bit of dismantling and is best done by a mechanic, but is this just one of these OTT things? It certainly doesn't look too difficult, but of course these things can be deceiving.
    Reason I ask is that the warning lamp came on tonight, and one of the main beam bulbs was out. I gave the lens a thump and it came back on, but I suspect it's on the way out, although I suppose it could be a loose connection.
    I've had both the front sidelights replaced, and they're not that easy to get out - I couldn't do it myself, but a mechanic with long fingers managed one and I think they used long-nosed pliers for the other one.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  2. Re: Changing headlight bulbs
    Dec 2007
    Beleive it or not, I heard the Halogen bulbs are covered for 4 years and 50,000 miles under VW warranty. Not sure if this applies to you, but it won't hurt to give your ******* a call and find out...
    As for advice on self fitting... I had an horror story of having to take of a front bumper to get a bulb changed for my 2003 Alfa 156, but I have not yet had the "Oppertunity" to do this on my passat.... yet!
    2005 VW Passat B6 2.0TDi SE | Shadow Blue | Electric Seats | F/R Parking sensors | Cruise Control | 72k | Chrome Grill
  3. Re: Changing headlight bulbs
    Sep 2007
    South Manchester
    I upgraded my dipped bulbs to Philps Xtreme, A vanity mirror & torch came in handy. I would imagine the mains will be similar. I also was sent some blue vision sidelights but gave up as just too tight a space.
    VW Passat Estate 2.0 TDI DSG in Silver 2006
  4. Re: Changing headlight bulbs
    Rutland
    Have a look here http://forums.vwvortex.com/zerothread?&id=2706234
    Dips are much more accessible but principles are the same. Connectors on my car's dips are different to those on this North American spec.car.
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  5. Re: Changing headlight bulbs
    Quote Originally Posted by gazza007 View Post
    It was actually dipped beams I meant gazza; I thought main beam meant the same as dipped beam, but perhaps main beam is the same as full beam
  6. Re: Changing headlight bulbs
    Sep 2007
    South Manchester
    You will be able to do it Stuart
  7. Re: Changing headlight bulbs
    Gazza
    How would you rate the Philips Extreme bulbs for light output? A bit better, or loads better?
    I was thinking of getting some myself, but past experience with other uprated bulbs was that the improvement in light output was marginal.
    Mike
  8. Re: Changing headlight bulbs
    Sep 2007
    South Manchester
    Hi Mike, I think it was worth it not a massive improvement but much better than supplied bulbs. This is where I got them from.
    Have ordered the Philips X-treme + 80% for £26.99 from Autobulbsonline, best price I could find.
    http://www.autobulbsonline.co.uk/#Anchor_Philips_Xtreme
    You also get a set of sidelight bulbs, so quite a good deal.
    http://www.autobulbsonline.co.uk/#An...W__Blue_Vision
  9. Re: Changing headlight bulbs
    Nottingham
    I changed my dipped bulbs for HIDs at the weekend and the difference is tremendous. I went with 6000K bulbs and although fiddly, the entire process only took an hour or so, so replacing the bulbs alone could probably be done in 5minutes. As long as you leave one side untouched then you can refer back to the clip and bulb position and you can get away without using torches and mirrors etc.
    I would highly recommend it.
    ps: I don't have particularly small hands or long fingers.....!
  10. Re: Changing headlight bulbs
    Well the bulb's been fine since it went out temporarily a few days ago, so I haven't had a chance to put it to the test.
    I'm certainly encouraged by the comments in this thread though
  1. Headlight Bulbs
    By Michelin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 02:42 AM
  2. Changing headlight bulbs on Polo 1.4TDI Xreg 2000
    By porthcawlmike in forum Polo - Derby - Lupo - Fox
    Last Post: 07-11-2007, 02:34 PM
  3. changing the bulbs on a mk4 golf
    By eghuws in forum Golf MK4 - 1999 - 2004
    Last Post: 04-07-2007, 02:28 PM
  4. changing bulbs
    By jack71 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-06-2007, 02:36 PM
  5. Headlight switch bulbs gone
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 08:35 PM
