Thread: noisey engine 1.4 bca
  1. Exclamation noisey engine 1.4 bca
    May 2008
    having probs wit my 03 golf tapping from head changed tappetsand roller rocker arms both for the new revised versions but no joy still the same using long life oil .any ideas before i rebuilt engine with only 40k on it
  2. Re: noisey engine 1.4 bca
    did you resolve your problem? my is 02 golf 1.4 bca engine and tapping noise, also misfire for cylinder 3,low compression there.85 psi. Others around 170.Looks like valve burnt.I poor some oil into cylinder,compression rose.So rings should be okey.Some sugested to look for replacement engine.i also noticed sump repair.May be this wehicle ran without oil for some time.Can i use other code 1.4 engine?Thanks for any help.
  3. Re: noisey engine 1.4 bca
    no one knows about the noise, then i know now- its hidraulic tapets some of them were squashed.Can anyone tell is it posible to take engine from mk5 golf 1.4 bud code and fit to mk4 golf 2003 which had bca engine 1.4.
  1. Noisey engine when starting from cold
    By pg20 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-05-2008, 11:29 PM
  2. Noisey at startup
    By melcon in forum Audi A3 - Archive Topics
    Last Post: 25-03-2008, 09:31 AM
  3. Noisey gearbox?????
    By Nick142 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-12-2007, 06:56 PM
  4. Noisey Air Conditioning
    By timothy_iles in forum Golf MK4 - 1999 - 2004
    Last Post: 14-07-2007, 02:33 PM
  5. noisey engine
    By kharva007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-04-2007, 08:10 AM
