Thread: 1988 GTi 8V 1.8 How many gears?
Results 1 to 8 of 8
  1. 1988 GTi 8V 1.8 How many gears?
    May 2008
    Hi All,
    New to the forum and to VWs but finally bought a Mk2 like I always wanted however it has only a 4 speed box fitted.
    Is this the correct box for the car?
    I thought that the Gti's were all 5 speed but I don't know much about Golfs so I could well be totally wrong.
    According to the ad it has a ACD gearbox? and a PB Digifant engine.
    It needs a bit of work doing as when I was on my way home the clutch broke and the gear change is very very sloppy. It's booked into the garage but they can't look at it for a week.
    Anything you can tell me would be helpful
  2. Re: 1988 GTi 8V 1.8 How many gears?
    May 2008
    Anyone have an 8v GTi with a 4 speed box?
  3. Re: 1988 GTi 8V 1.8 How many gears?
    May 2008
    I'm going to get the gear linkage changed to see if that will let me get into 5 gear as in another vwmk2 forum people were talking about the gear linkage giving problems with 5th gear.
    I think I've got a 020 box fitted as it has the round cap at the wheel end. I still can't tell if it's the correct box for the car though. The clutch cable is a manual adjusting one.
  4. Re: 1988 GTi 8V 1.8 How many gears?
    May 2008
    After a bit of a play around with the linkage I've found the elusive 5th gear!
  5. Re: 1988 GTi 8V 1.8 How many gears?
    Jun 2008
    Quote Originally Posted by Frijj View Post
    did you change the linkage ? as mine will go into 5th gear some times but very occaionally will struggle to go in
  6. Re: 1988 GTi 8V 1.8 How many gears?
    May 2008
    The gear stick had been set up so far to the right that it wouldn't go into gear. When this was set up correctly you could (mostly) get it into 5th. I've now had a new clutch fitted but the gearbox was badly worn and leaking oil so I've had that fully rebuilt and the linkage rubber grommets replaced at the same time.
  7. Re: 1988 GTi 8V 1.8 How many gears?
    Aug 2009
    Glasgow
    my mk2 has sticky gears going into 5th and 2nd, if you put it back into neutral then select the gear its fine, was maybe thinking of changing the linkage. is yours woking ok now its set up right ?
  8. Re: 1988 GTi 8V 1.8 How many gears?
    May 2008
    the linkage helped but if it's crunching in 2nd then it's new box time / rebuild time as the syncro will be worn out.
    It could just be that the bit labled 3 in the picture is not done up right.
    The linkage bits are cheep enough from GSF and for 5th gear it could be the short connecter
    Got some part numbers in this link and a bit of a guide:
    http://www.vwgolfmk2.co.uk/modules.p...iewtopic&t=117
  1. 1988 Gti Golf Loses Power
    By garyurunlimited in forum Golf MK2 - 1984 - 1992
    Last Post: 13-05-2008, 11:32 AM
  2. mk2 1988 1.6ez suspension upgrade
    By nhoj62 in forum Golf MK2 - 1984 - 1992
    Last Post: 07-04-2008, 09:55 PM
  3. 1988 Golf GTI 8v
    By DUBMEISTER_G60 in forum Golf MK2 - 1984 - 1992
    Last Post: 14-02-2008, 02:01 AM
  4. Replies: 5
    Last Post: 20-04-2007, 08:04 PM
  5. Golf 1.3 cl 1988 engine electrical problem?
    By Nelson in forum Archive posts
    Last Post: 30-09-2006, 12:04 PM
