Thread: 1.8T Sport electric probs?
  1. Question 1.8T Sport electric probs?
    Jul 2006
    Have a 1,8TS Passat with 120k showing. It's been really great up to now (apart from the ABS controller falling over!!!) However, the central locking doesn't work remotely now - can centrally lock using the key in the locks. I've changed the batts twice (just in case) to no avail. Also, the 4 rear speakers mounted in the rear doors have stopped working. Does anyone know if these faults are related? If so, is it an easy fix? Any help appreciated. Al B
    Jun 2006
    I had that central locking problem where it only worked on the key. Although on mine it was coupled to a failure of the drivers window to raise or lower automatically at a touch of the button ie: it would only work under continuous pressure.
    The problem turned out to be a couple of broken wires in the drivers door loom, the bit in the rubber boot between door and body. You know that bit that's a right little B*****D to get at? If I recall correctly I think I soldered mine for peace of mind, if yours turns out to have the same problem, that's the solution I would recommend as the loom is pretty stressed at that point and I think crimp connectors or the like will only cause further problems in the long run.
    Good luck cos as I seem to remember the loom wasn't the only thing stressed by the time I had finished.
    I don't think the speaker problems are related to the locking one (go on someone prove me wrong) but I would have thought there would have been a stack of ICE fans out there to give an answer to that one.
    Jul 2006
    Thanks for that Wookie. I've a leckie looking at the central locking problem tomorrow. He seems to think the fob may need re-programming or something. I've also been advised that the stereo speaker problem sounds like it may be the radio at fault. I thought it may have been a faulty or loose connector but I don't know how to get the radio out. Any help out there?
    Dec 2006
    Durham, England
    Hi there,
    After speaking with a VW technician there is a known problem on the Passat. The connector that lives inside the B-pillar is prone to water damage and rust and these get repaired a lot by VW. Apparently they are a problem to get to and repair and when removing the interior trim the bits tend to break off. Might be worth getting a quote to get the work done and let the VW techies sort it out as it might be cheaper. Hope it helps, David.
  1. Sport in May or Sport GT in June?
    By LimEs in forum Chat - Anything with wheels
    Last Post: 23-06-2007, 03:19 PM
  2. mk 2 gti 8v probs
    By mk2.8v in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-06-2007, 06:59 PM
  3. Electric window mechanism jammed TDI sport Passat 52 plate
    By Tony31 in forum Chat - Anything with wheels
    Last Post: 29-04-2007, 10:43 PM
  4. New A4 Few Probs
    By ben21 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-01-2007, 11:15 PM
