Thread: AUDI 80SE 2.0L 1994 ECU problem
  1. Cool AUDI 80SE 2.0L 1994 ECU problem
    Dec 2006
    South Wales
    Hi All, I hope someone can help.
    My Audi has developed a fault where the spark voltage at the ignition coil is very intermittent, the garage says that the signal to the ECU is ok but the signal to the ignition coil is absent. I hope that the ignition coil is ok, (I replaced it in july 2006,) so I need to have the ECU checked out. The question is: - does anyone know where it is?
    Thanks all, Happy New Year.
    Steve.
  2. Smile
    Dec 2006
    South Wales
    Thanks for the offer Andy, but I've got some good news. I removed the battery to charge it, once done I replaced it and started to check through the sensors, the signal to the coil power stage looked as if it was ok so I re-connected it and gave it a go. hey presto the beast is back and running again. so it looks as though that all the ECU needed was to be reset, I'm still worried that the problem will come back again though.
    Steve.
    Nov 2006
    Hi Andy... is there a way to check the Hall sender unit? And the ignition switch? I've an intermittant problem with an ABK engine (2.0E 1995) and am trying to find it the problem (seperate thread). I have a decent multi-meter and am on to check anything that could help. Even Audi haven't been able to find the problem after been in the garage three times - too damn intermittant a problem. Its the Digifant (sp?) system I think.
  1. 1994 Audi 80 2.0 (ABK) Not firing
    By vImTo in forum 80 - 90
    Last Post: 09-05-2007, 10:22 PM
  2. Audi 80SE Intermittent loss of accelaration
    By rossclan in forum 80 - 90
    Last Post: 21-04-2007, 10:26 PM
  3. 1994 Passat 1.9 TDI - Gear Selection Problem
    By paularcher in forum Passat - Archive Topics
    Last Post: 11-02-2007, 12:24 PM
  4. 1994 AUDI 80 - firing sequence
    By herschy in forum Chat - Completely Off Topic
    Last Post: 18-10-2006, 05:06 PM
  5. Audi 80-1994 TDI
    By John R. O'Neon in forum 80 - 90
    Last Post: 19-06-2006, 06:54 PM
