Thread: V5 cold start problem
  1. V5 cold start problem
    V5_170Mk4driver Guest
    I have a 2003 Golf 2324 V5 170bhp (AQN)
    It has recently developed a cold start problem. Before the fault developed, if I started my car from cold, the engine would rev straight to about 1100rpm for a few seconds before settling to 1000rpm and then later to the usual 850rpm. When I started the car from warm, the engine would go straight to 850rpm and settle immediately. I imagine this is controlled by the ecu via some sort of temerature sensor.
    The Fault:
    My engine is now very reluctant to start from cold. It will not fire unless I give it a squirt of throttle to get it going. If it does start it climbs very slowly to 850rpm as though it is already warm. Am I right in thinking that some sort of sensor has failed, or become disconnected.
    I have recently had the car serviced and a new water temperature sensor has been fitted to correct a guage fault. This seems to be working correctly. I have also recently cleaned the engine bay out. Just the usual sponge and a bit of hose pipe to rinse. NO JET WASH USED.
    I have cleaned the engine bay like this before and have encounted no problems.
    I know its a bit sad but I have video'd a cold start and put it on youtube to hope it might help one of you diagnose my problem. On the third attempt to start I gave it a squirt of throttle and it started.
    Youtube link http://uk.youtube.com/watch?v=tREKKwCtfKQ
    Can anyone help??????????
  2. Re: V5 cold start problem
    Just putting it back up the list.
    Got no replies last time.
  3. Re: V5 cold start problem
    To me it sounds like a faulty ignition switch,as if you hear a relay dissengage before you let go with the key on of the start position
  4. Re: V5 cold start problem
    coolent temp sensor ? it may be fauty and trickng the ECU into thinking its warm
    1.8T AUQ head standard engine. Newsouth performance Boost, Oil pressure and Temperature gauges, 6 spoke TT alloys and A8 interior light.
    Next engine
  5. Re: V5 cold start problem
    I've just had the coolent temp sensor changed as the previous one had a fault. The new one looks ok by how the temp guage works. But it does sound like the most likely cause.
  1. Cold start problem
    By jb1978 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-04-2008, 04:26 PM
  2. Cold start problem
    By nel636 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2007, 04:40 PM
  3. Cold Start Problem
    By robdcaterham in forum Archive posts
    Last Post: 21-03-2007, 07:24 PM
  4. cold start problem on A4 99'
    By wescyj in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 10:49 PM
