Thread: Passenger Door Electric Window Help
  1. Passenger Door Electric Window Help
    May 2008
    Hello friends, i have a torn in my side. Up untill yesterday my passenger window (MK3 GTi 2door) was working now it is stuck down switches for passenger door don't work but the drivers side is fine. there is no unsual noises to indicate faulty window motor/regulator the switches will just not work the passenger window. i do have a cobra alarm fitted. come to think of it the passenger side was working intermittently when driving, so i would switch engine off try the window switch & it worked. i should have guessed trouble ahead. so where do i start my diagnosis. would someone pls. put me out of my misery....thanks in advance
    Last edited by wacovi; 05-05-2008 at 11:28 AM. Reason: I did not explain myself properly
  2. Re: Passenger Door Electric Window Help
    May 2008
    check the wiring in the door jam.
  3. Re: Passenger Door Electric Window Help
    May 2008
    thanks spiderrm for your reply. what i did was to go ahead with regulator replacement since i couldn't find any broken wires nor faulty door switch. the gumble paid off, now electric window works...
  1. passenger door window
    By sheerah in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2007, 07:59 PM
  2. Passenger door window has disappeared!
    By greengeorge in forum Golf MK5 - 2004 - 2009
    Last Post: 01-10-2007, 05:15 PM
  3. Passenger side electric window
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2007, 06:00 PM
  4. Sharan electric window, passenger side
    By paulnh in forum Touran - Sharan - Caravelle
    Last Post: 21-06-2007, 08:37 AM
  5. Passenger door window problem
    By Phillsoton in forum Touran - Sharan - Caravelle
    Last Post: 31-08-2006, 11:45 PM
