Thread: Reduce emissions
  1. Reduce emissions
    Bristol
    was wonder if this can be used to reduce Emissions,
    Channel 3: EGR
    • To decrease the EGR rate, increase the number to the highest possible value (typically 33768).
    • This will prevent/slow down the intake manifold clogging problem and reduce smoke.
    • Though the MAF at idle is still within specifications (370 mg/h) do not use this adaptation on the road :-)
    • Again, this EGR setting is for off-road use only !!!
    Although I have a hole near the cat, I want to make sure it passes its re-test after the new cat fitted , as it failed on Emissions
    MK5 Golf TDI 2.0ltr GT Sport in Black
  2. Re: Reduce emissions
    Magdeburg, Germany
    Nope.
    Sebastian @ www.Ross-Tech.com
  3. Re: Reduce emissions
    Bristol
  4. Re: Reduce emissions
    Hey..... You have provided very useful information ......well.....you have done a great job.....
    keep it up....
  1. How to reduce the sensetivity of the [factory std] alarm
    By Jasonz in forum Golf MK4 - 1999 - 2004
    Last Post: 24-04-2008, 01:38 PM
  2. '96 s6 emissions too hi?
    By jtb008 in forum New Member Introductions
    Last Post: 26-02-2008, 06:34 PM
  3. emissions
    By bora03 in forum Bora - 1998 - 2005
    Last Post: 06-01-2008, 05:29 PM
  4. MK3 1.8 ABS emissions?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 14-12-2007, 05:45 PM
  5. A4 emissions
    By spellmaster in forum Chat - Completely Off Topic
    Last Post: 04-10-2006, 10:11 PM
