Thread: Brake lights
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Using VAG-COM to diagnose a faulty Brake Light Switch
    Mar 2007
    U-96
    Quote Originally Posted by elPaulio View Post
    Nice write up mate!!
    Explains a lot about why this fault appears to be popping up more often!!
    Much kudos to you!!
    Paul
    Thanks Paul,
    Your gratitude is truly appreciated .
    Regards,
    TR7
  2. On the subject of brakes...
    Leicester
    I have just connected up to my A4 (B6) for the first time with VAG COM (409 shareware) and done a couple of fault scans on different control modules. When I went into 03-ABS Brakes there was a beep and "BRAKES" flashed up on the DIS (giving me a slight brown trousers moment I must admit!)
    I did a fault scan and it found no faults, then when I exited the module the DIS went back to normal and all appears to be fine. Should this concern me, or is it to be expected?
    Thanks!
    Ade
  3. Re: On the subject of brakes...
    Dec 2007
    Suffolk
    Quote Originally Posted by A4Ade View Post
    It does that to warn you its not working while its in diagnostic mode.
  4. Re: On the subject of brakes...
    Angus, Scotland
    Yeah, it's totally nothing to worry about. I recall having a similar brown trouser moment when I first did it on my Golf
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  5. Re: Brake lights
    134 Post(s)
    2019 Post(s)
    When I do a full scan on a car I often wander off as it is a bit boring, I have lost count of the number of times the customer has run over with arms a flapping and brown stains on their pants going “arghh, the ABS light is flashing and it’s beeping, oh God, oh God I’m pooing myself!”. People do tend to panic when it involves cars and money.
  6. Re: Brake lights
    Leicester
    Thanks for the responses fellas - that's good to know
  7. Question Re: Brake lights
    #17
    Jul 2008
    New Zealand
    I'm coming to this a bit late as we've only just bought a '97 A4 TDi Quattro.
    On a journey south through France, hundreds of miles from home, the glow plug light started flashing. Bit worrying, and a quick flick through books of words suggested this was due to an 'engine management fault'... Hmmm.
    I couldn't feel anything wrong and no other alarms, alerts or warnings were displayed. The light stopped flashing shortly after.
    On the way back from France the bulb out light was displayed and this proved to be the two outer brake lights that weren't working - the centre light worked fine. This time it was around midnight, pouring with rain and we were just off the ferry at Newhaven, still a couple of hundred miles from home. No real choice but to press on, and shortly after the warning light went out and the brake lights started working correctly again. They're still fine.
    I've checked the brake light switch (looks like its the earlier type) and I'm sure it needs adjusting so I'll try that before investigating further. Any comments? Any advice welcome!
  8. Re: Brake lights
    #18
    134 Post(s)
    2019 Post(s)
    Replace the switch, they cost less than £15 genuine.
  9. Thumbs up Re: Brake lights
    #19
    Jul 2008
    New Zealand
    Thanks - didn't realise they were so reasonably priced.
  10. Re: Brake lights
    #20
    134 Post(s)
    2019 Post(s)
    If you don’t ask…
  1. Brake lights
    By dmcquade in forum Audi A3 - Archive Topics
    Last Post: 06-04-2008, 03:13 PM
  2. a3 brake lights
    By mike21201 in forum Audi A3 - Archive Topics
    Last Post: 31-03-2008, 07:49 PM
  3. brake & warning lights
    By mark williams in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2008, 03:38 PM
  4. brake lights
    By sydaz in forum Touran - Sharan - Caravelle
    Last Post: 10-12-2007, 09:29 PM
  5. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
