Thread: lugg comp open
  1. Question lugg comp open
    midlands
    Hi I've had trouble with a leaky rear washer which was causing a fault with the boot lid switch. The alarm thinks its open causing the alarm to go off. I've cured the leak but not the alarm problem. Any suggestions? Do I need a new switch on the lock?
  2. Re: lugg comp open
    Jan 2008
    Bath, Somerset
    Might need a new one, or there is corrosion in the lock from the leak causing something to short and give the wrong readings...
  3. Re: lugg comp open
    I just had the same issue last week.. hairdryer over the boot lock for a while, some WD40 and a few hot days driving with the windows open has fixed it for me
  4. Re: lugg comp open
    midlands
    thanks.
  5. Re: lugg comp open
    midlands
    Its stopped working completely now! I can't open the boot at all not even with the key. it won't turn in the lock. I'm having to access the boot through the folded down rear seat! LOL. Looks like an expensive dealer job!
  6. Re: lugg comp open
    Did you remove the boot trim and give it a good run over with a paint stripper or hair dryer?
    Look around the joins of the mechanical parts and also where there are any electrical connections. A liberal spraying of WD40 (shield your face) and driving with the windows open should fix it after a few days unless it's a long term problem and has caused serious corrosion to electrical connections.
    EDIT: how did you cure the leak? did you do the full DIY job with piping or did you just re-seat the collar connector (it may be split like mine was).
  7. Re: lugg comp open
    midlands
    Hi Solari. I did take the trim off,eventually. We had a bit of trouble getting it off. the pipe was off but not broken. I put it back on then secured it with sillicon sealer and 2 little cable ties as they do in the factory. I didn't dry it as such because it was already dry. This problem has been on going for about 3 months and have only just got round to fixing it. I haven't used the rear wash-wipe since so it can't be more water in there. I sprayed the lock mechanism with WD40 and 'worked' it manually quite a few times and it seemed quite free. Then next day, boot lock stops working altogether! its still like it now.I'm loathed to go to VW cus I can't really afford to re-mortgage!
  8. Re: lugg comp open
    I'm wondering if delaying looking at it could have been the primary factor here, as any electrical contacts will have had time to corrode It might be worthwhile looking for an independent VW specialist rather than taking it to VW as they will probably try to sell you the whole Boot lock or washer assembly at an inflated price
  9. Re: lugg comp open
    midlands
    Too true! thanks for your help. I'll have a look around for an independant.
  1. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  2. On board comp help
    By the taz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 02:37 AM
  3. Caption Comp
    By TheWills in forum Chat - Anything with wheels
    Last Post: 08-01-2008, 11:55 PM
  4. VW Golf GTTDI (150) AC Comp' clutch
    By stevemurrell in forum Golf MK4 - 1999 - 2004
    Last Post: 09-07-2007, 04:08 PM
  5. 1996 Polo: Where is luggage comp light switch?
    By dukla2000 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2007, 07:38 PM
