Thread: Sunroof Queries!?!
Results 1 to 8 of 8
  1. Sunroof Queries!?!
    Kent
    Hello everyone, i was wondering if i could get sum advice on a sunroof.
    Firstly i think theres a problem with my sun roof because when accelerating or stopping i can hear the water in the roof,
    Second, sometimes it leaks out the sides, or out of my light where my sun visor is.
    Any ideas on fixing the problem? or anyone had this problem?
    Cheers guys
  2. Re: Sunroof Queries!?!
    Chester-le-Street, United Kingdom
    Quote Originally Posted by andy_c_v View Post
    Cheers guys
    open the roof up and look into the corners of the channels, you should see some drain holes,which i believe have pipes attached internally which run down to the door pillars and drain out in the area of the door hinges or there
    abouts. they are certainly blocked up by the sound of it. a plastic cable tie, or stiff wire may help unblock them,
    good luck,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Sunroof Queries!?!
    Kent
    I just had a look and i saw two holes in the corners closest to the front of the car and they seem clear!
    Are these the ones you are on about?
    I did try putting a coat hanger down but no noticable progress
  4. Re: Sunroof Queries!?!
    it's just something i read, but it sounds that they would be the ones.
    try looking on the door pillars,perhaps try from the other end?
    only read about it,never seen it.
    4th cog,--two to go
  5. Re: Sunroof Queries!?!
    Kent
    Ok im goin to investigate further, Thanks for the advice stewy, much appreciated
  6. Re: Sunroof Queries!?!
    Aug 2007
    get a jug of water and pour it very slowly into the guide channels with the roof open. Wait about 20 seconds then look under car, should be some water either side if the channels are not blocked.
  7. Re: Sunroof Queries!?!
    Quote Originally Posted by STEWY L View Post
    just a thought, but how about a bicycle pump, or foot pump, or if you have access to a compressor, blow either up,or down the holes with an air line.
    if that is not possible for you, then go to an independent garage and ask them to do it. it shouldn't cost a fortune to clear the drains.half an hour perhaps,with an air line?
    keep hold,
    stewy.
    4th cog,--two to go
  8. Re: Sunroof Queries!?!
    Kent
    Yea that sounds like a good idea, ive got a air compressor at work, the drain holes go to the underneath of the car? i will have to further investigate that, let u kno how it goes.
    Thanks again
  1. MMI Phone Queries
    By Akash in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-04-2008, 09:15 AM
  2. suspension queries first post!!
    By 5hwaa in forum Golf MK4 - 1999 - 2004
    Last Post: 22-02-2008, 09:47 AM
  3. MK4 GTI 1.8T CAI queries
    By wezzzor in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2007, 02:08 AM
  4. Please Help - cylinder head queries
    By jamie211983 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-08-2007, 06:06 AM
  5. Aux. belt and alternator pulley change/queries
    By dvhttn in forum Passat - Archive Topics
    Last Post: 22-03-2007, 08:29 PM
