Thread: Radiator Fan!!!
Results 1 to 9 of 9
  1. Angry Radiator Fan!!!
    May 2008
    Got a Mk3 GTi and the radiator fan has decided to stop working. Can't isolate the fault nor can i recall when it last worked!
    I've changed the temp sensor and the fan switch in the radiator, and also checked the fuse, which seems ok.
    Has anyone had this fault or know if there is a relay which controls the fan which could be dead???????
    Any advice would be appreciated, Cheers!
  2. Re: Radiator Fan!!!
    Mar 2007
    I think from other posts if you've changed the switch then the fan is the next change...according to Haynes it is a marvellous job which the bumper and radiator have to come out b4 you can get to the fan...I'm just about to start this myself and am still hoping someone can tell me there is a much easier wa about it (particularly hacked off as not long flushed refilled and bled the coolant system not difficult but a pain in the a$%e).
  3. Re: Radiator Fan!!!
    Mar 2007
    Try this link top post says how to test fan...if it don't come on then new one needed
    https://www.vwaudiforum.co.uk/forum/s...t=30895&page=2
  4. Re: Radiator Fan!!!
    May 2008
    Forgot to mention that!!! i tried testing the fan, and it worked fine on both fast and slow speed. The rads been bled since the fan switch was changed and still nothing. Both top and bottom pipes are getting hot and the heater's blowing warm in the car. Waterpump has relatively recently been changed. Cheers for that though!
  5. Re: Radiator Fan!!!
    133 Post(s)
    1986 Post(s)
    If the fan works with the plug bridged out and the top and bottom hoses get hot then the only explanation is a faulty fan switch.
  6. Re: Radiator Fan!!!
    May 2008
    Just to let anyone know, incase they have the same problem, i have fixed the problem. There was no live feed to the faan switch. Traced the wire back to the fusebox. Just before it enters the bulk head in the engine bay, The wire had been rubbing against the manifold breather over the years and haad arked!
    The fun i had replacing that yesterday! She's all good now though!
    Thaanks people!
  7. Re: Radiator Fan!!!
    133 Post(s)
    1986 Post(s)
    So you didn’t test the fan by bridging out the switch plug contacts? It would have saved you a lot of time.
  8. Re: Radiator Fan!!!
    Are you sure tthe fan comes on at first ans second velocity??? or only one, with switch ingnitionj on??
  9. Re: Radiator Fan!!!
    133 Post(s)
    1986 Post(s)
    Which version of the Golf 3?
  1. radiator fan replacement
    By domross in forum Golf MK3 - 1993 - 1999
    Last Post: 19-04-2008, 06:35 PM
  2. air con radiator
    By subly in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-03-2008, 01:22 AM
  3. 80 Td Radiator
    By Shearer85 in forum 80 - 90
    Last Post: 29-05-2007, 01:44 PM
  4. Radiator
    By goonda in forum Passat - Archive Topics
    Last Post: 18-04-2007, 11:03 PM
  5. New Radiator
    By humberdale in forum Passat - Archive Topics
    Last Post: 21-11-2006, 08:44 PM
