Thread: tyre pressure
Results 1 to 10 of 14
  1. tyre pressure
    Can anybody help????
    Ive fitted a set of 20 inch rims to my new audi a3. they fit perfect and im using pirelli 235 30 20 P- ZERO NERO tyres !
    i got a puncture in one and the tyre blew its wall , shortly after another 2 punctures. the tyres all failed before the tread got low the garage put 30-32 psi in at first and said maybe the psi was too low...
    the next set i used 40 psi(max pressure is 50) and 2 blew out the same time and these tyres have only been on a week the 2 i had left have cracks on the walls like that of a tyre thats been on ages but my tyres still have the knobbles on and the tyre fitting paint....they have just gone down over night, the tyres would have worn in the middle on my old set if id over inflated and rubbed on the edges if under but the first set worn evenly and ive never had a nail in any of them......i know all the simple rules but i dont know where to turn and its costing me a fortune, ive just bought 2 new tyres last week and the walls have slit already, these tyres are gonna be the death of me if i dont get to the bottom of it
    what on earth am i doing wrong? please help me!
  2. Re: tyre pressure
    Cheshire, or my A6
    I am assuming the car was fine before you put 20s on it?
    Maybe 30psi is too much, my A6 takes 30 yet that has 235/45/17s. Either that or the wheels themselves are puncturing the tyres, it would be nice to know where exactly on the tyre that the puncture was.
    Paul
  3. Re: tyre pressure
    kimandsally Guest
    Some where there is a way to identify the age of the tyre, I can't find it, I'm sure it was on some tyre website.
    I think the tyres "might" be old stock from what your saying.
    By the way Welcome to the forum.
  4. Re: tyre pressure
    The wheels are fairly new and the first set of tyres lasted nearly 75 % of tyre wear but then they just gave up and cracked .
    There is a possibility that these tyres are old stock because these tyres are a very low profile and are not common at all.they are splitting on the walls after a few days.there are no nails or holes to cause the tyre to go down other than the cracks in the side walls also there is no puncture hole as you would normally find on the tread area.
    do you think 1f a 17 inch is 30 psi....a 20 would be greater psi at say 40...or would the psi decrease to say 25???
    Thanks for your help!
  5. Re: tyre pressure
    Northampton
    I may be talking rubbish, but surely the pressure in a tyre is related to the weight of the vehicle to the area of the tyre on the road. So if a 235 wide tyre is 30 psi for an A6, then with the A3 being lighter, the pressure should be less, not more.
    As for tyres showing wear centre tread for over inflation, it would take some miles for this to show. From what you say you are hardly getting off your driveway before these are failing. I'd have a word with your tyre supplier - they seem sub-standard to me. Had your wheels been at fault, then your fitter would surely have said something.
  6. Re: tyre pressure
    Cheshire, or my A6
    You say the tyres fit perfect, well they might fit while the car is stationary but as you go over bumps the tyres could be catching the arches just slightly. What size have you taken off the car? You could try finding a speed hump or something and getting somebody to watch you over it to see what's happening.
    Paul
  7. Re: tyre pressure
    Its really hard for me to give every detail without writing an essay lol
    i would expect that most people who have this type of tyre on their car either dont go far due to the expense of replacing or have a super car that they dont do alot of miles in so never get the problem i have.. i would expect that a tyre that has been designed for toring cars should last a few trips on the public roads.
    This is my car that i use for work, i could do 100 miles in a day sometimes.its not practical..i know but i love my car..i would expect to have each set of tyres for at least 10000 miles but after 3 or 4 motorway runs in a straight line...they are shot at
    these wheels fit with no rubbing at all and were made and imported from holland even when everybody i spoke said they would never fit,i have a full turning circle without any rubbing, even at speed.
    plus can anybody help me with the last question???? if i have a 19 inch tyre at 35 profile and say 30 psi --- will a 20 inch tyre with 30 profile have less or more pressure than a 19 . thanks again guys
  8. Re: tyre pressure
    Cheshire, or my A6
    Quote Originally Posted by martin007 View Post
    Answer to your last question, I would say slightly less, but only about 5 psi max. Probably about 2 or 3 psi I would have thought.
    Paul
  9. Re: tyre pressure
    Feb 2007
    Nottingham
    Why don't you give Pirelli a bell and see what they say they must have a customer support department? 20's on an A3 is a large tyre but they seem to have run ok in the past. If i had a tyre fail after day's no way i'd be paying for a new set, they're clearly not fit to purpose
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  10. Re: tyre pressure
    I rang pirelli today and they told that these tyres have never been tested as they are not standard fit on any production car.
    they told me that ideally, i should not exceed standard size by over 3 %.
    they said 19 s were the biggest i should go for safety, i spoze they are right but the 20 s look fantastic.
    They also told me that i was exceeding the load on the tyres and my car was too heavy ...????... but if an a3 is too heavy and these tyres or made for touring cars... what car could they possibly go on ? they had no answer for that,There is no feedback on the tyre at all , no data at all, !!!! ? Mine is a 2.0 TDI a3!
    I DONT GET IT AT ALL !
  1. Tyre Pressure
    By yas1320 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2008, 11:28 AM
  2. Tyre Pressure
    By Somerset 4motio in forum Chat - Anything with wheels
    Last Post: 10-03-2008, 10:19 PM
  3. Tyre pressure help please
    By minimonte in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2008, 05:12 PM
  4. Just gone to 17" what should my tyre pressure be?
    By ldormon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2007, 08:34 PM
  5. Tyre pressure gauge
    By Mav2006 in forum Archive posts
    Last Post: 28-03-2007, 07:32 PM
