Thread: 2.6 V6 Thermostat change
  1. 2.6 V6 Thermostat change
    May 2008
    Good morning.
    I have a 1997 A4 avant 2.6 ABC that I'm looking to change the thermostat on, and am wondering if anyone could tell me whether it is possible to remove the thermostat without removing/disturbing the cam belt?
    Thanks in advance for your help.
    Jason
  2. Re: 2.6 V6 Thermostat change
    london/ UK
    Quote Originally Posted by JasonR View Post
    Good morning.
    Jason
    You will need to remove cambelt in order to replace thermostat. Is the car overheating ? I suggest you check watter pump first, as the impaller is made of plastic and they are known to fail/spin on the shaft ! I offer a cambelt replacement for about 300 pounds and includes new water pump(Meyle/KWP with metal impeller), Contitech cambelt + tensioner(Littens), Contitech auxiliary belt and AC belt as well. I am based in N. London, but i can travel to you if within reasonable distance ! Regards, Chris-07789912128.
  3. Re: 2.6 V6 Thermostat change
    May 2008
    Hello Chris
    Thank you for the quick reply and the offer to carry out the work.
    The car is running a bit cool, 75degrees most of the time but does go to 90 after a long drive. This is what is making me think that it is the thermostat.
    The waterpump,belts and tensioner and viscous coupling were all replaced 12 months ago by the previous owner but he ignored the thermostat which is handy!.
    I currently have the lock carrier set to the service position but haven't removed the serpentine belt yet and was hoping that i could get away with replacing the thermostat without buying the cam timing tools.
    Thanks again for your help
    Jason
  1. 80 TDI thermostat change
    By Grey Import in forum 80 - 90
    Last Post: 21-02-2008, 12:41 AM
  2. Thermostat change
    By tricky262000 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2008, 09:56 PM
  3. A6 2.6 V6 ('94) Thermostat.
    By karlosjackel in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 31-03-2007, 03:50 PM
  4. How to change thermostat on 2000 jetta
    By mannyojeda in forum Archive posts
    Last Post: 07-03-2007, 08:02 PM
  5. Thermostat - where?
    By mattj in forum 80 - 90
    Last Post: 11-07-2006, 02:52 PM
