Thread: How to replace Oil Pressure Switch?
  1. Exclamation How to replace Oil Pressure Switch?
    mbohea Guest
    I have a 1995 Golf Mk3 CL with an oil light/buzzer problem.
    The light and buzzer will come on and stay on when the revs to a certain speed. I have looked into this problem online and see that other people are experiencing a similar thing.
    Ive tried 10W oils instead of 5W as suggested by someone online, have tried disconnecting & reconnecting the battery and nothing works.
    Another suggestion is replacing the Oil Pressure Switch. Now i know nothing about cars so i have taken some photos to show you all. I think theres an oil leak aswell as the bit i believe the switch is - is covered in oil.
    Ive looked at switches on ebay etc and they look pretty simple to fit - just screw in tight and reconnect the wire?
    Are there any important steps i need to take before i unscrew the broken one one? I dont want to make matters worse.
    I believe the Oil Pressure Switch the white bit you can see in the photos? What is the similar looking one to its left?
    http://i83.photobucket.com/albums/j2...d/Image103.jpg
    http://i83.photobucket.com/albums/j2...d/Image104.jpg
    http://i83.photobucket.com/albums/j2...d/Image105.jpg
    I have a Haynes maunal and cannot find any info on it so i have turned to this forum.
    All help greatly appreciated!
    Matt
  2. Re: How to replace Oil Pressure Switch?
    mbohea Guest
    well i fitted it.
    is very easy, but hasnt fixed the problem.
  3. Re: How to replace Oil Pressure Switch?
    london/ UK
    I think the next item on the list is the oil pump and a new set of tappets !
  4. Re: How to replace Oil Pressure Switch?
    mbohea Guest
    Ok il look into those.
    Thanks for the advice.
  5. Re: How to replace Oil Pressure Switch?
    Oct 2007
    You Have 2 oil pressure switches on your engine.But what you need to do is check the oil pressure to find out if it is a mechanical or electrical fault
  6. Re: How to replace Oil Pressure Switch?
    Jan 2008
    hi ya i have a 8v gti 2L recently had the oil light coming on and beeping i changed to oil pressure sensors and the rocker cover gasket and the problem went a way....... 1st sensor is on top of the oil filter and the second is in the side of the engine just down from the rocker cover i advise taking them out one at a time and writing down the part number and pressure bar then go down to your nearest vw dealer and get the genuine part cost me about £9 each parts might of been upgraded hence going to the dealer to check the part numbers are correct replace again one at a time think its a 22 or 24 mm spanner or socket
    hope it helps
  1. oil pressure switch
    By ggg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2009, 09:43 AM
  2. Which colour oil pressure switch
    By radfordlad in forum Golf MK3 - 1993 - 1999
    Last Post: 08-03-2008, 12:28 PM
  3. oil pressure switch...
    By JimiG in forum Alhambra
    Last Post: 27-02-2008, 01:19 PM
  4. Oil Pressure Switch 2.5tdi (AFB)
    By no smoke in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-09-2007, 10:59 AM
  5. Oil Pressure Switch
    By e6m6a6 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-06-2007, 05:42 PM
