Thread: problem idling
  1. problem idling
    Aug 2008
    Bridgend
    hi guys i was wondering if you could help me i have a 1.6 adui 80 se on a 94 plate and when she gets warm the revs and oil pressure drop when shes at idle i dont have a clue what it could be any ideas??
    many thanks
    Paul
  2. Re: problem idling
    Jun 2007
    Gwent
    I don't know the 1.6 engine, but generally the oil pressure drops off with a warm engine compared to cold, if the idle is slow, the oil pressure will be extra low due to this.
    If it is still low at normal idle revs then I'd suggest fresh oil and filter, a higher viscosity oil eg 15W-50 grade would probably help.
    The low idle could be caused by a vacuum leak, so check the air intake hoses for splits etc and check all the small bore vacuum hoses off the intake manifold.
    Other than that it is common for the throttle body to get coated with oily gunge - from the crankcase breather system. If you clean out the insides of the throttle body and throttle butterfly with a clean rag and some carb cleaner/petrol, this may help.
    There is often an idle stabiliser valve that is supposed to help control idle speed, yours may not have one or this too could be gunged up?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. 1.6se Idling problem.
    By andyha2000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2010, 01:31 AM
  2. MK4 Stalling/idling problem
    By TommyG 69 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-12-2007, 09:22 PM
  3. idling problem with A6 Avnte 2.6 A/T
    By lappies in forum Chat - Anything with wheels
    Last Post: 22-11-2007, 08:15 PM
  4. Cold Idling Problem
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 02-07-2007, 08:19 PM
  5. E Reg Golf Idling Problem
    By EIMB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-03-2006, 05:04 PM
