Thread: 1997 Sharan TDI-Which Engine?
  1. 1997 Sharan TDI-Which Engine?
    Bit of a newbie question really, my 1997 P sharan has the 1.9tdi engine fitted--the numbers i can find in the handbook are 7mvv038146--is my engine the 90 or 110bhp engine?
    thank you
  2. Re: 1997 Sharan TDI-Which Engine?
    Bern, Switzerland
    The engine type will give you the information, my 99 sharan has a white sticker on the back tail gate when open by the closing mechanism. This has the engine type on it (81KW 1.9ltr. / AFN,AVG and 66/81KW 1.9ltr. / 1Z,AHU,AFN, AVG and 66KW 1.9ltr / ANU).
    Otherwise look in the manual for the car type (mine is a 7M8288) and list the engine type which will also give you the info on it.
    The other place is on top of the timing belt cover is the engine type but it is hard to look at it has been cleaned or covered in crap.
    Another way is to go to your local VW dealer with the VIN number and they can tell you which engine you have.
    Gory details try Fred's TDIclub: http://tdiclub.com/TDIFAQ/TDiFAQ-2.html
    Also try VAGcat for info on parts: http://www.vagcat.com/
  3. Re: 1997 Sharan TDI-Which Engine?
    134 Post(s)
    2005 Post(s)
    It will be an AFN
  4. Re: 1997 Sharan TDI-Which Engine?
    so would you say the afn is 110bhp as the cam cover has no identifying stickers neither are there any around the car?
  5. Re: 1997 Sharan TDI-Which Engine?
    134 Post(s)
    2005 Post(s)
    Yes, the AFN is 110PS, 81Kw.
  1. A4 1.8T AEB engine 1997 No Spark on 2
    By chancer514 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-03-2008, 03:28 PM
  2. 1997 Sharan glow plug relay - where?
    By the_old_diver in forum Touran - Sharan - Caravelle
    Last Post: 19-12-2007, 07:14 PM
  3. Sharan tdi 1997 - No brake lights and Heat coil light flashing
    By hawkz_2002_uk in forum Touran - Sharan - Caravelle
    Last Post: 16-09-2007, 07:20 PM
  4. 1.4L 1997 Polo - engine cut out
    By MikeJBro in forum Polo - Derby - Lupo - Fox
    Last Post: 21-05-2007, 11:18 AM
  5. Sharan 1997 TDI Cluster Lights
    Last Post: 23-09-2006, 05:38 PM
