Thread: Audi a4 tdi turbo problem
  1. Audi a4 tdi turbo problem
    Hi all.iv got an R reg audi a4 tdi estate AFN engine code.
    when driving the turbo works fine for a untill you reach 3 or 4 gear or a period of time and then there is no power at all in the engine.
    as soon as you switch the ignition off and then back on the power is back as it should be.
    any suggestions?thanks
  2. Re: Audi a4 tdi turbo problem
    Could be the air flow meter or the actuator arm, try taking out the air flow meter and spraying some carb cleaner through it. The sensor can get dirty quite easily, especially if the air filter hasn't been changed in a while.
    If that doesn't work try putting some wd40 on the actuator arm, this will only help temporarily, but is a quick check to see if you need to take it out and loosen it up.
    link to thread dealing with loosening actuator arm:
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=31278
  3. Re: Audi a4 tdi turbo problem
    May 2007
    Leeds
    it could also be a dirty variable geometry mechanism. maybe even more likely than the actuator arm. sort it out as soon as possible, what you are getting is limp mode. good luck.
    ex Audi 1.9 TDI 1997, AHU
    Audi 1.8 Petrol/LPG
    Audi 1.9TDI AFN Quattro
  1. Turbo problem
    By chrisvrscrx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2015, 10:06 PM
  2. Turbo problem
    By J-DiZZle in forum Golf MK4 - 1999 - 2004
    Last Post: 31-12-2007, 02:04 AM
  3. 1997 audi a4 turbo sport problem
    By yeti67 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2007, 07:17 PM
  4. audi 80 1.9TDI Turbo problem
    By szoke91 in forum 80 - 90
    Last Post: 13-06-2007, 08:00 PM
  5. A6 Tdi turbo problem
    By Angie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-10-2006, 07:05 PM
