Thread: Reversing sensors fitting to A4 Avant
  1. Reversing sensors fitting to A4 Avant
    Near Bristol
    Has anyone fitted these before?
    http://www.parkingsensors.co.uk/dolp...ng_sensors.asp
    I have just bought a set of these and after checking under the bumper have found a huge reinforcing section running full length - at the reccomended fitting height. If i want to fit them into just plastic i would have to put them almost on the bottom edge of the bumper - lower than recommended height, and then really only have room for three out of the four because of the exhaust?!
    So has anyone succesfully fitted four to a 2001 A4 Avant and if so where were they put? - Thanks.
    P.S Would it be o.k to drill through the reinforcing section to fit them (in terms of safety of the car and correct working of the sensors)
    2001 (Jan) A4 1.9 TDI SE
  2. Re: Reversing sensors fitting to A4 Avant
    it would not affect the strenght of the bumper beam if you were to drill the holes for the sensors,that is where audi would fit them anyway
  3. Re: Reversing sensors fitting to A4 Avant
    Oct 2007
    South Wales
    i mounted mine further down in the diffuser bit of my S4 bumper to avoid hitting the rebar
    1.8t conversion : SP51x OUTLAW Turbo @ 25psi : Vmaxx Coils : 6 Speed 'Box : GripForce Stg 3 Clutch : S4 Leather : Facelift Console
    Anyone want to swap my A4 for an A3 or similar?? PM me
    243 bhp @ 6415 / 275 torques @ 3370 Chipped UK Rules
  4. Re: Reversing sensors fitting to A4 Avant
    May 2007
    best place to fit them is correct height, reinforcing bar is aluminium, and will not be effected by you drilling 4 20mm holes in it.
  5. Re: Reversing sensors fitting to A4 Avant
    Oct 2007
    South Wales
    Quote Originally Posted by lonky View Post
    Thats true, but as my car is lowered anyway i would have to have stuck them in the bootlid to keep the height to spec. then when i read into it, the sensors are tapered, so to mount them lower i "aim" them up. Works a treat for me
  1. Advice needed on fitting VW Park Sensors
    By mikecb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2008, 09:58 PM
  2. Fitting Reverse Sensors
    By carltabs in forum Golf MK5 - 2004 - 2009
    Last Post: 16-03-2008, 08:22 PM
  3. Fitting rear Parking Sensors?
    By zeratul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2008, 08:44 PM
  4. A6 Reversing Sensors
    By chrissy077 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-11-2007, 04:07 PM
  5. Towbar query - reversing sensors on vehicle
    By Corsadad in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 04-10-2007, 12:57 PM
