Thread: V5 Cam sensor fault
Results 1 to 10 of 10
  1. V5 Cam sensor fault
    Hi I Have a 2001 V5. Engine code AZX. It said on the machine that it had a fault with a camshaft sensor so i replaced both and the crankshaft senson but i still have the same fault and the same fault codes coming up. The car runs rough on idle only. Please help.
  2. Re: V5 Cam sensor fault
    What are the readings you get?
  3. Re: V5 Cam sensor fault
    134 Post(s)
    2021 Post(s)
    Cam timing?
  4. Re: V5 Cam sensor fault
    Mar 2008
    camshaft position adjustment sensor?.
  5. Re: V5 Cam sensor fault
    134 Post(s)
    2021 Post(s)
    There is no adjustment of the sender G40 itself.
    What code are you getting, 16395, 16396, 16398 or 16399, 16725, 16726, 16727, 16730, 16731 or 16732?
  6. Re: V5 Cam sensor fault
    Apr 2017
    GB
    Pointless response, why I don't use this site much lmao
    Sent from my Nexus 6 using Tapatalk
    0 0 1
  7. Re: V5 Cam sensor fault
    134 Post(s)
    2021 Post(s)
    What are you on about, this one of the most stupid comments I have read on here for a long time about an over TEN year old post where I asked a question and did not get the courtesy of a reply. If you don't like this free to join, free to use service where you get free professional help, then you can take your custom elsewhere, I can close your account if you wish!
  8. Re: V5 Cam sensor fault
    Apr 2017
    GB
    Close it ya *****, done here calling me stupid.
    Made a mistake not quoting Kenny but I'm far from stupid you jumped up little ****.
  9. Re: V5 Cam sensor fault
    Apr 2017
    GB
    P.r.i.c.k. and t.w.a.t.
  10. Re: V5 Cam sensor fault
    134 Post(s)
    2021 Post(s)
    Lovely person.... Anyway, what was wrong with what Kenny said?
  1. help!! cordoba turbo fault. 1 sensor or 2?
    By gemmell88 in forum Ibiza - Cordoba
    Last Post: 07-02-2009, 12:55 AM
  2. Fuel level sensor fault?
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2008, 11:41 PM
  3. A4 2001 Speed Sensor Fault
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2007, 06:48 PM
  4. Accelerator sensor fault..
    By seatarosa in forum Arosa
    Last Post: 23-08-2007, 07:05 PM
  5. Mass Airflow Sensor Fault
    By bamjimpat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-08-2007, 09:57 PM
