Thread: Broken Rear Coil Spring
Results 1 to 8 of 8
  1. Broken Rear Coil Spring
    Leatherhead, Surrey
    Hello
    My 2002 Golf GTi 2.0 has just failed it's MOT due to a broken rear spring. I have a replacement and am looking at the Haynes Manual and it seems like a fairly simple job to replace it (either using a spring compressor or not ).
    Can anyone give any advice on just how simple or difficult this is before I start work? Any suggestions to make the job easier?
    Many thanks
    Peter
  2. Re: Broken Rear Coil Spring
    Leatherhead, Surrey
    Hello
    I have now replaced the broken spring and found that, actually, it was remarkably easy. It took just over 1 hour to replace one spring using spring compressors. I did not attempt to try it without the compressors (as described in the Haynes manual) so cannot comment on this method.
    So if you have a broken rear coil have a go yourself - much quicker and cheaper than taking it in for repair.
    Peter
  3. Re: Broken Rear Coil Spring
    134 Post(s)
    2019 Post(s)
    Support the axle on one side under the spring plate, remove both damper lower bolts, unclip the ABS wires, lower the axle down and remove the springs.
  4. Re: Broken Rear Coil Spring
    Feb 2007
    Nottingham
    I've never come across a car that you can't do without compressors as most cars hold their suspension under some tension at all times
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  5. Re: Broken Rear Coil Spring
    134 Post(s)
    2019 Post(s)
    I have never done the springs on a Golf 4 platform car with spring compressors, far too much trouble.
  6. Re: Broken Rear Coil Spring
    Feb 2007
    Nottingham
    How does one do them without?
  7. Re: Broken Rear Coil Spring
    134 Post(s)
    2019 Post(s)
    As above.
  8. Re: Broken Rear Coil Spring
    most cars with a rorsion beam rear axle and springs that are seperate to the shocks are easy to do springs,it gets more complicated when you have integral springs/shocks as in the audi a4/passat/vectra and any other car that uses integregated springs that you need spring compressors
  1. Change front coil spring polo
    By gyprgy in forum Polo - Derby - Lupo - Fox
    Last Post: 20-05-2008, 09:35 AM
  2. Broken rear wiper spring
    By RodCouncil in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-04-2008, 08:19 PM
  3. Coil Spring Help
    By krobb45 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2007, 06:09 AM
  4. front right coil spring
    By xiangyu19 in forum Beetle 2000-
    Last Post: 10-12-2006, 04:46 PM
  5. Broken rear window
    By oceanwizard in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-11-2006, 05:10 PM
