Thread: Newbie-Some Advice on tickover/Starting Problem
  1. Newbie-Some Advice on tickover/Starting Problem
    Hi all
    Just joined the forums really to get some advice on a running problem with a little Polo in the family. I've no real knowledge of Vdubs and this is the first I have ever really come across so here goes:
    Polo 1 litre p-reg manual 5spd
    Changed oil and cleaned out spark plugs, carb flap and rotor cap and ever since had problem with tickover and starting:
    When driving it and changing gear the revs stick up at about 1500-2000 RPM and don't come down, this was prevalent right after service. As soon as the car is brought to a stop the revs seem to recover to normal tickover in two stages over say 5-7 secs, 1st stage down to about 1300 then to just under 1000rpm.
    I done the service about a week and a half ago and yesterday, when I went to start her, it started then died. it done this 6 times before starting!!
    Funnily enough the engine is actually running better than it used to; it's just this tickover and now starting malarky I can't figure out.
    Any advice and forethought would be appreciated before I get delved into it over the weekend....
    Andy
  2. Re: Newbie-Some Advice on tickover/Starting Problem
    May 2008
    Did you mess up the timings? Rotar arm and distributor so cheap you might as well replace not clean.
  1. Newbie looking for Advice
    By Browny_37 in forum New Member Introductions
    Last Post: 10-03-2008, 06:30 PM
  2. newbie advice please . . .
    By Ewan71 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2007, 11:48 PM
  3. Newbie In Need Of Advice
    By junior in forum New Member Introductions
    Last Post: 27-05-2007, 07:17 PM
  4. Newbie---advice and hello
    By Flanders in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-02-2007, 10:48 PM
  5. VW POLO 1.3i tickover problem
    By burt in forum Chat - Completely Off Topic
    Last Post: 11-04-2006, 09:34 AM
