Thread: climate control
  1. climate control
    Aug 2006
    CAN ANY ONE HELP I HAVE A 1997 A6 1.9TDI AFTER ABOUT 30 MINS OF RUNNING THE CLIMATE CONTROL STOPS WORKING AND GOES ONTO FULL FAN BLOWING COLD. LEAVE THE CAR FOR A FEW HOURS AND IT ALL WORKS AGAIN PERFECTLY FOR 30 MINS THEN MY FEET FREEZE
  2. Climate Control A6
    Nov 2006
    Southampton
    There are a number of sensors which provide the climate controller with the necessary information to determine whether the temp in the cabin is below the desired temperature hence it will heat, or above the desired temperature hence it will cool.
    I suspect one of those sensors is malfunctioning, from the symptoms you described, it is probably a temperature related breakdown of the sensor, ie it works perfectly when cold from startup,but then malfunctions after it has warmed up.
    As there are a number of sensors at different locations, the best way to check is to get the climate controller interrogated to determine if there are any fault codes present, if there are the fault code should tell you which sensor is at fault. I don't know if you can get this done independently or if you need to take it to Audi.
    Hope this helps
    Regards
    Gazza57
  1. B6 Climate control V B7
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 10:44 PM
  2. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  3. A4 CLIMATE CONTROL
    By Bob R in forum Chat - Completely Off Topic
    Last Post: 06-04-2007, 02:51 PM
  4. climate control, please help
    By jessicaart in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-01-2007, 06:57 PM
  5. Climate control?
    By El Dingo in forum Audi A4 - Archive Topics
    Last Post: 01-07-2006, 11:38 PM
