Thread: 12v source near the centre console
  1. Question 12v source near the centre console
    Pidge_MKV Guest
    Where is the easiest place to get a 12v source for my new Brodit Tomtom mount?
    Ideally something or somewhere that will not void any warranty - I was thinking the cig lighter socket? The mount has a red and black wire and a small box that needs hiding - is there room under the ashtray?
    I am mounting the mount on a dashmount on the left handside of the radio.
    Thanks,
    Neil.
  2. Re: 12v source near the centre console
    Coventry
    are you after a permant live or switched live.? Switched i would assume.
    If so, test the functionality of the econ buttonin conjunction with the ingition. if it turns on and off in conjunction with the ignition, then find the wire that goes to the econ buttton and locate the switched live wire with a multimeter. For earth/ground, use the brown wire coming out the radio.
  3. Re: 12v source near the centre console
    Pidge_MKV Guest
    I don't have an Econ button, only A/C... Is this the same thing?
    I have just had a parrot fitted with multican for my steering controls... Could I get the power from here?
  4. Re: 12v source near the centre console
    Coventry
    likely,
    locate the switched live.
  5. Re: 12v source near the centre console
    Pidge_MKV Guest
    Quick thought - what about the hazard switch?
  6. Re: 12v source near the centre console
    put a multimeter across the lighter - mine was a switched live and then Scothlok into it
  1. how to remove A6 centre console?
    By polosbruno in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-04-2008, 07:48 PM
  2. centre console noise
    By CY294 in forum Touran - Sharan - Caravelle
    Last Post: 13-03-2008, 09:37 PM
  3. Centre console - B5.5 into B5?
    By Alun in forum Passat - Archive Topics
    Last Post: 26-01-2008, 03:42 PM
  4. Centre console removal?
    By orion1210 in forum Audi A3 - Archive Topics
    Last Post: 01-04-2007, 08:53 AM
  5. Audi 80 centre console
    By Andy8legs in forum 80 - 90
    Last Post: 28-09-2006, 01:22 PM
