Thread: Aerial replacement
  1. Aerial replacement
    I need to replace the radio aerial on my 94 audi 80. It's already been snapped off from the rear wing and the sleeve inside is also missing. Can I replace simply with another like for like part or is it more awkward than this. Any tips to look out for would be most appreciated as you can guess I've not had to replace one before so don't know where to start.
  2. Re: Aerial replacement
    Gloucestershire
    Just done this on my 94 80E Saloon, it's easy enough, remove the left hand side panel trim carpet stuff, you will see the aerial, it's a case of unscrewing the lock nut on the top the aerial (outside) and then undoing the small nut which holds it in place on the inside, withdraw it from the wing, unscrew the cable from the aerial mast and then screw this cable in to the new mast, fit the new mast through the hole in the rear wing, fit and secure the lock nut then fit the small nut to the bracket, job done. I got my aerial from GSF, it was about a fiver, took a bit of sorting out on their part to get the right one but take the car to your local branch and they will be able to match it up for you.
    It's easy enough when you see the job.
    Audi A3 1.8 20v 1998
    Audi A6 2.5 TDi 1996
  3. Re: Aerial replacement
    Thanks for the guidance, just got to get right aerial to match which as you said shouldn't be a problem.
  4. Re: Aerial replacement
    Aug 2009
    Worcester, UK
    Did you manaqe to find a replacement aerial for your 80? I have the same problem with my '92 2.0 16v and haven't been able to source one yet. Any ideas please? Thanks so much.
  5. Re: Aerial replacement
    Jul 2009
    Leyburn, North Yorkshire
    Quote Originally Posted by TrevorMc View Post
    Found this one on fleabay.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260339544760
    Fitted ok but sticks out at an angle slightly from the car and cheap as chips.
    Also my original aerial was not held in by a nut on the outside - simply a matter of pulling pretty hard from inside the boot and then using pliers to remove the rubber ferrule going through the wing. Works absolutely fine.
  6. Re: Aerial replacement
    Aug 2009
    Worcester, UK
    Thanks - looks & sounds good enough. Did you have to re-wire or did the replacement screw into the original wiring connector ok?
  7. Re: Aerial replacement
    Jul 2009
    Screwed straight on, no problem.
  1. a3 aerial
    By squinty in forum Chat - Anything with wheels
    Last Post: 26-04-2008, 09:48 PM
  2. Where's the aerial?
    By c0l in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 12:45 PM
  3. Aerial Base Replacement
    By onloantoton in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2007, 09:34 PM
  4. Replacement base for aerial on 2003 Golf
    By radiofc in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-08-2007, 08:43 PM
  5. 52 reg A4 aerial amp
    By Eclipse car Audio in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-01-2007, 11:27 PM
