Thread: A3 spark plug change!
  1. A3 spark plug change!
    I am looking to change the spark plugs on my 1999 1.6 petrol A3 and the Haynes manual suggests that I have to take off the two-piece inlet manifold. I can access the outer two plugs but the middle two are covered by the manifold.
    Does anyone have any tips for changing the plugs without taking it all to bits?
    Many thanks
  2. Re: A3 spark plug change!
    Hi, I recently changed plugs on mine, i spent ages fiddling trying to do the job, ended up having to take off the top half of the manifold, there is just enough room to get them out then :-) It all really straigh forward.
    Hope this helps.
  3. Re: A3 spark plug change!
    Mar 2008
    Any chance you could knock a guide together for doing this?
    Or even better, a guide on how to do a complete service on a 2.0 TDI
    Cheers,
    TheEggShell
  4. Re: A3 spark plug change!
    Just follow your haynes manual on removing upper half of the inlet manifold, its a very acurate description, just bear in mind that if you unplug he throttle body wire you will have to realign it with a vag, haynes doesn`t tell you this.
    Have fun....
  5. Re: A3 spark plug change!
    Hi All
    Many thanks for your help, it's all done now.
    Thanks again
  1. Spark plug gap?
    By Jayc530 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 06:11 PM
  2. Ignition coil and spark plug change problems
    By Raj in forum Golf MK4 - 1999 - 2004
    Last Post: 29-02-2008, 05:44 PM
  3. v5 passatt spark plug change
    By clixmick in forum Chat - Anything with wheels
    Last Post: 27-10-2007, 10:04 AM
  4. A6 Spark plug gap?
    By gooders30 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-08-2007, 06:05 PM
  5. Correct spark plug gapping
    By SosolidVw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-04-2007, 08:19 PM
