Thread: hazard light and indicator problem
  1. Smile hazard light and indicator problem
    I recently bought a used, T reg VW passat 1.8 s from a dealer. I am experiencing a new problem now. As soon as I put on the hazard lights it will blink for little while and it is going to a stationary mode after that. This is the same problem with the side indicators as well.
    When I spoke to the dealer they told me it would be 'relay problem' which is not covered under their warranty. Could someone please tell me what is meant by the relay problem and how do I fix it and how much approximately it may cost to fix.
  2. Re: hazard light and indicator problem
    7 Post(s)
    The hazard switch also incorporates the indicator and hazard relays.
    Quite a common failure but only about £20 and an easy diy fix.
    This should sort it.
  1. Help.Hazard Light on Dashboard
    By pops11 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2010, 12:06 PM
  2. S3 How do I remove the piano-black trim to get at hazard/indicator relay?
    By TCullen in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 22-04-2008, 11:36 PM
  3. 96 A4 Indicator/hazard light woes... still
    By Dex2034 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-03-2008, 09:18 AM
  4. Hazard/Indicator relay change
    By Bluoranges in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-08-2007, 04:10 PM
  5. Hazard Lights/Indicator problems
    By Ricky_TT in forum Archive posts
    Last Post: 14-05-2007, 01:25 PM
