Thread: problem with miss fire on bora
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. problem with miss fire on bora
    Dec 2006
    if any one can help me i have a bora 1.6 16v aus engine 2000 model when the car is on tick over the engine sounds like misfire the exhaust is like popping sound then it goes smooth then popping again and also if you drive it as soon as your about to go it stalls recently i noticed my coolant was a bit low so i ask a m8 to check it he removed the timming belt and notice a slight leak on the water pump when he removed it the propeller on the back had broken off so he replaced it then said i will change the timming belt while he was there he did the job and told me to collect the car i took it home as i got home it stalled on me but started to idle up and down on the revs has any body any idea what this could be
    Dec 2006
    Chelmsford, Essex
    Did your friend disconnect the battery when he replaced the pump and belt?
    ill tell you what i think, unless your 'm8' knew what he was doing and had all the cam locking tools, chances are hes knackerd up your timing, unless you or he knows how resolve this, get it to a garage ASAP, i dont need to explain to you the damage you can do to an engine if the timing is out.
  4. problem with misfire on bora
    Dec 2006
    he did not take the battrey off at all but when i got home i removed the earth terminal from the battrey for half hour and restarted the engine but no difference at all
    Dec 2006
    [he siad he had trouble trying to get the crankshaft pulley off so he took it to a garage and they removed off with an air gun then tighened it back up then got back to his place and removed the pulley he used some locking tools on the camshaft and he said he went off the timming behind the pulley on the crankshaft if the timming is out by a fraction will the car still run?
    if the timing is completly out, the car will still run but the timing of the pistons, valves and when the fuel is 'combusted' will all be out of sync, you are risking the chance of major engine failure if the timing is out. from what my brother and several fiat lovers told me, pistons hit valves, cam belts snap, tensioners fail. in essence, if your timing is out, you should not drive the car. i believe golfs have been identified as an 'interferance' engine, which means should the cam belt fail it will take most of the rest of the engine with it. you need to get your timing checked. this was fairly simple for my fiat, unsure about the golf? all i did was take out the plugs and leads, lock the cam in place, put some 12cm dowels in the holes where the plugs were and you can see how much the timing is out by the position of the dowels, simple thing to do was to rotate the engine by hand until they were level...hence timing correct. unsure if you could apply the same principle to the 1.6 16v? i defintley wouldnt be driving it whilst you're unsure though!!
    Dec 2006
    Thanks for that will i be able to check the timming with a timming light or is that just for the old cars? well if not i phoned my local vw dealer and to put the car on a diagnostic machine it would cost 45 quid which seems a bit much is their anybody in my area who has a scanner to test the car i am in ashton under lyne.
    Dec 2006
    Manchester
    I live down the road in clayton, but no machine sorry!!!!
    hi, i live in stalybridge and have both a fault scanner and vag com but a scanner wont help your timing. im not too sure about vag com as im sure you can assess it using that, but unsure how to! that £45 fault reading diagnostic wont do much to be honest, itll just show certain sensors are out of range in most probability, due to the timing being out. you need the timing checked, not the engine fault management system. i suspect that wil be quite expensive, unless your m8 knows how to check the timing himself?
    Dec 2006
    VAG-COM will have logged faults if the time is out... more than likley it will show a misfire or crank sensor to high/low..
    I would have a look at the timing first things first... however it also sounds like a coil back may have gone down,,, these cost £25 each..
    if your mates claims the timing is perfect... have try the below....
    If you dont have VAG-COM and want "try" and fix it you can do the below..
    I would go buy a coil pack,, £25 each in the UK, then take out coil pack number 1, and go for a drive... if no different... replace the exisitng one and then try in number 2.. and so on to coil pack number 4... - once you have done this and "IF" its better in one postion leave it there...
    I would then recoomend reaplcing the other 3 as they will be next to go... or its upto you..
    RickT
  1. miss firing
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 12-07-2007, 11:22 PM
  2. Audi Missed Recall On A6 Leads To Fire
    By loyal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2007, 06:18 PM
  3. engine keeps miss-firing (2001 golf tdi se)
    By sheepsteeth in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 05:46 PM
  4. 96 Golf 1.9 TD Won't Fire on Start-up.
    By Redbaron in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-03-2007, 10:18 AM
  5. audi 80 tdi mis-fire
    By Benny in forum 80 - 90
    Last Post: 27-01-2007, 06:57 PM
