Thread: diesel
  1. diesel
    derby
    can someone help.
    I collected my golf gt sport 170 a month ago running fine so far 1350 miles
    on the clock i have been useing standered diesel up to now.
    I have thought about using shell v-power diesel now i know this has been on the market for a while now. so i thought i might give it a try as i have herd it
    gives off less smoke and improves power and so on. Also i thought it might help keep the dpf filter to keep clear longer ie less smoke.
    Has anyone tried this and was it any good..
  2. Re: diesel
    Mar 2007
    coventry
    i have found the same only i use asda with a litre of petrol
    no matter how you try you always come back to what you first started
  3. Re: diesel
    Mar 2008
    WOW, using both diesel and petrol???
  4. Re: diesel
    Angus, Scotland
    Is that a VAG approved fuel??
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  5. Re: diesel
    Mar 2007
    coventry
    no this subject started when i owned a 900rr i used to fill the tank but add a small ammount of model fuel to the tank i can say there is a slight difference.
    with the diesel v-power i have found the same just a slight difference
    the asda diesel with a litre of petrol is a old trick from the landrover days
  6. Re: diesel
    Angus, Scotland
    Ahhh... the landie days!!!
    Can't beat a landie for teaching you all the little tricks you'll ever need can you??
  1. Diesel R8!
    By cmcb a3 in forum R8
    Last Post: 10-01-2009, 02:41 PM
  2. Differecne Diesel Golf GT 2.0 & Diesel GT 2.0 SPORT ?
    By johnd1881 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-08-2008, 07:33 PM
  3. Red Diesel
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2008, 09:49 AM
  4. MK3 AAZ Diesel - Bad MPG..
    By zub-gti in forum Golf MK3 - 1993 - 1999
    Last Post: 12-11-2007, 12:50 PM
  5. TT diesel is a must
    By Gary64 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 06-11-2007, 02:54 PM
