Thread: intermittent starting problem
  1. intermittent starting problem
    Mar 2008
    1.6 gl fails to start on occasions, no power to distributor, with a back feed this clears, but no faults show up, changed relay 30, no better, new ecu is £800, any ideas?
    james r
  2. Re: intermittent starting problem
    May 2008
    Replace ignition coil, £15 off ebay then starter motor £75....
  3. Re: intermittent starting problem
    Sep 2007
    I would definitily check the distributor, as my car suffered the same symptoms. No errors found using VAGCOM, but replacing the dizzy solved my problems. Many thanks to "Crasher", who figured this thing out for me
  1. Polo Starting Problem (intermittent)
    By Edmund in forum Polo - Derby - Lupo - Fox
    Last Post: 18-08-2010, 08:40 AM
  2. sharan intermittent starting sorted (hopefully)!!!
    By alice tinker in forum Touran - Sharan - Caravelle
    Last Post: 26-03-2008, 01:32 PM
  3. intermittent starting problem ? help
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 24-01-2008, 08:44 PM
  4. 1996 TDI Intermittent Starting Problems
    By mdcooper in forum Golf MK3 - 1993 - 1999
    Last Post: 29-11-2007, 10:18 PM
  5. VW Sharan SE Auto intermittent starting problem
    By Broley in forum Touran - Sharan - Caravelle
    Last Post: 19-02-2007, 12:51 AM
