Thread: Problems with DVD SAT NAV
Results 1 to 10 of 17
  1. Problems with DVD SAT NAV
    LEEDS
    Anyone experienced a malfunction whereby the sat nav cuts out and you get a message saying "the CD/DVD is unreadable please check CD/DVD". I took it into AUDI and they said the disk was filthy which they then cleaned but I still have the problem intermittantly, it's quite annoying when you're near the crucial bit of your journey and you lose navigation.
    Any ideas?
  2. Re: Problems with DVD SAT NAV
    Yateley, Hampshire
    Quote Originally Posted by SINGHY View Post
    Any ideas?
    I would say you require a new sat nav DVD.
  3. Re: Problems with DVD SAT NAV
    Scotland
    Sounds like your system is faulty. Could be a problem with the laser that reads the disc? Mine has been fine (so far). Where do you live? Some country's appear on both of the Sat Nav DVD's and you could try putting the other one in. Look on the back of the box and it tells you what countrys are on what disc.
    If at first you don't succeed, re-define success
  4. Re: Problems with DVD SAT NAV
    Aug 2007
    uk
    just got my new 07 A4 Avant , and it seems that the Sat Nav isn't working quite the way it should.
    When I bought it, the sat nav was miles out. it said I was somewhere 40 miles away. We thought it was a reception problem and it would cure itself with a bit of a drive.
    It didn't...
    When the nav-info is accessed, it says it is receiving no satellites.
    So the navigation is just working from the distance and direction sensors, and not the GPS, as you can place the car on the map manually and let it go from there, and it works. But if the car goes onto a transporter and doesn't physically move , then the satnav still thinks it is where it got onto the trailer.
    Its booked back into the dealers in the morning to have a look.
    Anyone heard of this before or had similar problems?
  5. Re: Problems with DVD SAT NAV
    Dec 2006
    Wiltshire
    You GPS antenna or the connections to it are borked. If it's under warranty the dealer should sort it quite quickly.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  6. Re: Problems with DVD SAT NAV
    Aug 2007
    uk
    Quote Originally Posted by Froggy View Post
    And it was the antenna - and they had a new one in stock and replaced it and its working great now !
  7. Re: Problems with DVD SAT NAV
    Aug 2007
    Newport, Wales
    7 Post(s)
    Any ideas?
    If your disc was filthy, I can only assume there is also dirt / dust in your Nav unit DVD area.
    As you drive, this dirt / dust gets shaken-up and interupts the laser reading the disc? just a thought.
    Perhaps it needs a good old clean out!
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  8. Re: Problems with DVD SAT NAV
    Mar 2008
    My original disk became unreadable, cleaned it but still says unreadable, bought new disk of e.bay same problem, but both disk 2's work fine
    Any ideas?
  9. Re: Problems with DVD SAT NAV
    Jun 2008
    Marmitehampton
    laser
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  10. Re: Problems with DVD SAT NAV
    Mar 2008
    If it is the Laser can it be replaced??
