Thread: 2.0tdi 170 sport estate
  1. 2.0tdi 170 sport estate
    Hi, I take delivery of a 07 2.0tdi 170 sport estate manual in a few days time. So while trying to find out a little more about them a came across this site. These seems to be a lot of talk regarding DPF.
    What is DPF?
    Do all tdi Passats have it?
    How do I found out if mine has it?
    If it has what difference does it make?
    Does anybody now if VW dealers can retro fit ipod connections?
    thanks
  2. Re: 2.0tdi 170 sport estate
    Scunthorpe
    Quote Originally Posted by kitch170 View Post
    What is DPF?
    thanks
    DPF - Wiki Quote:
    A diesel particulate filter, sometimes called a DPF, is a device designed to remove diesel particulate matter or soot from the exhaust gas of a diesel engine. Wall-flow diesel particulate filters usually remove 85% or more of the soot, and can at times (heavily loaded condition) attain soot removal efficiencies of close to 100%. A diesel-powered vehicle equipped with functioning filter will emit no visible smoke from its exhaust pipe.
    No, I don't think they all have them - Not sure how you tell TBH.
    And yes, they can. For £150 - I got an XCarlink adapter which worked fine up until recently, but that was a broken Stereo issue....
    PS, congrats on the purchase - hope you like it
    PPS, check for the ol' creaking suspension....
  3. Re: 2.0tdi 170 sport estate
    Dec 2007
    Epsom, Surrey
    the 170 engine has a DPF, it is designed to keep emissions down.
    You will need to drive the car quite hard (20 mins at 2.5K revs) at least once every 8-10 days otherwise the filter can get clogged, but a good drive brings the emissions temperature up and the soot gets burnt off.
    It is a cracking car, I have the SEL, and have covered 14K in not a lot of months. The ipod connector isn't worth it as you lose the MP3 compatibility on the stereo.
    MKVII Golf GTD Manual 5dr | Night Blue, Discover Pro, Dynaudio, DCC, Keyless Entry
  1. New Turbo@6500 miles 2.0TDI Sport
    By Jim Paton in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2008, 09:22 AM
  2. HELP with Engines 1.6FSi, 1.9TDi & 2.0TDi (Sport)
    By Jaimela in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-02-2008, 10:33 AM
  3. Touran 2.0TDI Sport
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 17-01-2008, 06:57 PM
  4. 2.0TDI Sport - Starts then cuts out after 500 yards
    By ibarker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 02:05 PM
  5. MPG Figures for A3 2.0TDI Sport Anyone?
    By shairaz1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-12-2007, 05:48 PM
