Thread: co or lamda sensor
Results 1 to 10 of 15
  1. co or lamda sensor
    hello there
    I"m a newbie here and i just wanted to know. I have a golf 3 GSX 1997 model. Does it have a co sensor? if so where is it mounted?
  2. Re: co or lamda sensor
    134 Post(s)
    2024 Post(s)
    What is the engine code?
  3. Re: co or lamda sensor
    well as i said i'm a newbie. where do i find that out?
  4. Re: co or lamda sensor
    134 Post(s)
    2024 Post(s)
    On your vehicle documents or service book, boot floor sticker, cam belt cover.
  5. Re: co or lamda sensor
    ok i'm not sure if this is the number but under type it's 1H4D if that make any sense.
  6. Re: co or lamda sensor
    134 Post(s)
    2024 Post(s)
    That is the type number, part of it anyway. What is the engine size and which country are you in?
  7. Re: co or lamda sensor
    i'm from south africa and it's a 1.8.
    i really don't know what number you looking for. do you have examples?
  8. Re: co or lamda sensor
    134 Post(s)
    2024 Post(s)
    Possibly AAM, ABS, ADZ or ACC.
  9. Re: co or lamda sensor
    Ok then it must be this number then AFV010743. hope that is the number you looking for
  10. Re: co or lamda sensor
    134 Post(s)
    2024 Post(s)
    I have a limited knowledge of SA market Golf 3’s even though we get a lot of UK market SA built Golf 3’s here around 97 to 98 but they are different.
    The AFV engine isn’t used in Europe at all but I have dealt with a very similar unit in the Citi Golf. As far as I can tell, the AFV doesn’t have a lambda sensor or catalyst.
  1. maf sensor
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 10:50 PM
  2. Map Sensor?
    By DekHog in forum Polo - Derby - Lupo - Fox
    Last Post: 11-08-2007, 11:08 PM
  3. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
  4. Lamda sensor
    By FEMI AJANA in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2007, 11:03 PM
  5. Map sensor
    By martyb123 in forum Archive posts
    Last Post: 19-01-2007, 12:19 AM
