Thread: Headlight question.
  1. Headlight question.
    Aberdeen
    Morning,
    A couple of q's re. my Mk5 headlights. Firstly one of the brackets has gone on my o/s headlight causing it to shake when driving (no noise but I can see my light beam vibrating of road signs while driving), my local VW dealer says that I need a complete replacement but I've heard that you can get a repair kit for the bracket, any of you done this before?
    Also (this is prob a nooby q) if I'm to upgrade my bulbs to halogen lights do I require different headlight units than the standard ones (which I must say provide as much light as 2 matches hanging off my car) or can I just change the bulbs?
    Thanks peeps,
    Rich.
  2. Re: Headlight question.
    Correct there is a repair kit available and it's about £15, it doesn't look pretty but it will do the job!
    If your dealer can't find it or are being idiots then the part numbers for a 2006 model (probably all the same) are :
    1k0 998 225 (Left)
    1k0 998 226 (Right)
    If you do not own a 2006 model then they can cross reference to see which ones will fit your car, but I'm 99% sure they're all the same.
  3. Re: Headlight question.
    Aberdeen
    Thanks mate, I'll look into it.
  1. Answer A Question & Ask Any Question?
    Last Post: 23-11-2011, 01:51 PM
  2. Headlight!
    By vw754 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2008, 11:17 AM
  3. Headlight Help
    By 01V5 in forum Bora - 1998 - 2005
    Last Post: 16-09-2007, 01:17 PM
  4. Headlight Help
    Last Post: 16-09-2007, 06:45 AM
  5. A4 Headlight
    By andrew00011 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-01-2007, 07:52 AM
