Thread: problem in turbo charger
  1. problem in turbo charger
    Mar 2008
    SLOUGH
    i have a AUDI 1996 90 BHP 1.9TDI
    WHEN I REV THE ENGINE ITS GIVES A STRANGE HISSING WHICH GROWS LOUDER AND LOUDER AS U KEEP INCREASING THE REVS AND DARK SOOT COMES WITH IT , IAM NOT GETTING THE REQUIRED TURBO BOOST. NOW CAN SOMEONE TELL ME WHAT COULD BE THE PROBLEM
    IS THE AIR MASS FLOW METER OR IS IT THE DUMP VALVE OR I HAVE TO REPLACE THE TURBO CHARGER.
    PLEASE KEEP IN MIND IT GIVES ME 575 MILES ON A FULL TANK ON THE MOTORWAY AND I CAN GO UPTO 110MPH
    KINDLY HELP ME
    CUZ THIS HISSING SOUND REALLY ****** ME AND WHEN ACCELARATING IT GIVES REALLY THINK SMOKE
  2. Re: problem in turbo charger
    Apr 2007
    Lancashire
    Sounds like a small boost leak.
    Check the charge pipe between turbo & intercooler for damage or leaks, and tighten up all the hoses.
    Also check the control tubing that connects the Turbo to N75, and N75 to wastegate actuator.
    Tighten all hoses/connectors associated with the turbo & charge pipes.
    Can you locate where the sound is coming from with an assistant revving the car?
    If it is not this check for leaks around the manifold with talc/chalk dust, or maybe EGR valve dodgy.
  3. Re: problem in turbo charger
    Mar 2008
    SLOUGH
    thanks for the advice i will check as u said on the weekend
    as u said to check from where the sound is coming
    it only comes when the car is running when the car is in neutral gear
    so i cant tell where the sound is coming
    regards
    Khurram
    Quote Originally Posted by ini View Post
  1. Turbo problem I think?
    By Bex9711 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2008, 08:14 PM
  2. 12V Charger only works when ignition is on?
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-01-2008, 11:38 AM
  3. Turbo lag problem
    By bankhead in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-11-2007, 02:51 PM
  4. Cooling Turbo charger
    By marcus in forum Audi A4 - Archive Topics
    Last Post: 12-11-2007, 04:20 PM
  5. Audi A4 1.9TDI 100bhp TURBO CHARGER NEEDED!!!
    By cha3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2007, 11:41 PM
