Thread: Exhaust Emission light
  1. Post Exhaust Emission light
    Mar 2008
    Light on the dashboard has just come up and been on continuously. Something i can check for? or does it need to go to the ********/local garage?
    Ta.
    2001 1.8T Sport b5.5
  2. Re: Exhaust Emission light
    May 2007
    I think that your car will need to be hooked up to a diagnostic machine, vag-com, so that the fault code can be read. So unless you know someone who has one you may have to go to a garage. That is unless someone on here can say otherwise
  3. Re: Exhaust Emission light
    Mar 2008
    managed to get a mate to connect up a vag-com and came up with the following results
    What i should mention is once faults were found, he cleared these off, and now the light (exhaust emission)has gone out, and hasnt come back on since then (but it has only been a few hours since being cleared)
    anyway these are the results:
    anyone able to make any sense of these?
    Ta:
    Address 08 -------------------------------------------------------
    Controller: 3B2 907 044 J
    Component: CLIMATRONIC B5GP 0001
    Coding: 17000
    Shop #: WSC 00028
    2 Faults Found:
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    37-10 - Faulty - Intermittent
    01274 - Air Flow Flap Positioning Motor (V71)
    37-00 - Faulty
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 3B0 920 925
    Component: KOMBI+WEGFAHRSP VDO V11
    Coding: 05415
    Shop #: WSC 00028
    WVWZZZ3BZ1P067576 VWZ7Z0Y3014779
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to B+ - Intermittent
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00004
    Shop #: WSC 00028
    1 Fault Found:
    01320 - Control Module for Climatronic (J255)
    49-10 - No Communications - Intermittent
    Address 46 -------------------------------------------------------
    Controller: 1C0 959 799 B
    Component: 6T Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 04926
    No fault code found.
    End -------------------------------------------------------
    b5.5 1.8T Sport (2001)
  4. Re: Exhaust Emission light
    May 2007
    I may be wrong, so don't take my word for it, but the emissions light could be linked to the coolant temprature sensor. Anyone else with any info please speak up. You could always take the fault list to your local vw garage and if the technicians are friendly enough they might be able to give you some clue what is important on that list and what isn't
  1. exhaust emission light
    By normanpalmer in forum Passat - Archive Topics
    Last Post: 30-01-2008, 08:56 AM
  2. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  3. 2002 VW Golf 1.4 - Exhaust Emission Light
    By BLUE in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-03-2007, 11:44 PM
  4. Golf V5 Exhaust Emission Warning Light
    By parkyv5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-01-2007, 10:51 AM
  5. exhaust emission warning light v6 4motion
    By stevie-g- in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-11-2006, 11:27 AM
