Thread: auto gearbox problem
  1. auto gearbox problem
    i drive a 02 passat,auto& tiptronic gearbox. sometimes it wont change gear,it keeps reving, sometimes up to 3000 revs and then it will jump into gear. i have to change into tiptronic to get it to change, when i do it also then jumps into gear. what could be the problem.
  2. Re: auto gearbox problem
    Cheshire, or my A6
    Post this in the VW section and you may get some answers. The first thing I always do is change the automatic transmission oil, if the problem persists I start to think hard.
    Paul
  3. Re: auto gearbox problem
    Dec 2006
    Hello and Welcome to the forum!!
    Rick
  4. Re: auto gearbox problem
    Oct 2007
    Hi The first thing you should do is have a fault code read
  5. Re: auto gearbox problem
    oil is low - when it gets past the level of the filter sucks air in so jerks or goes into neutral and then when level goes back the iar is pushed out - so top oil uo - cheapest method.
    if oil is low means leaking obviously somewhere - get the hoses for the cooling pipe checked first cuz can rust - and then the seals aswell - but do the easiest first otherwise youre paying for the box to come out.
    happenned to me and getting it fixed as we speak - leaky seepy hoses - audi quoted as a lie 590 pounds for a seal and gearbox removal - local garage said its a simple leaky hose - doing it for 150
    thank
  6. Re: auto gearbox problem
    i meant gearbox cooling pipes hoses not engine!
  1. sharan vr6 auto gearbox problem
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 30-06-2008, 10:04 PM
  2. Auto/tiptronic gearbox ecu problem
    By jewelldo in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 09:57 PM
  3. Auto gearbox problem with 02 TDI Passat
    By Kaiser2000 in forum Passat - Archive Topics
    Last Post: 11-11-2007, 04:26 AM
  4. 51 2.0S auto gearbox problem
    By kharva007 in forum Passat - Archive Topics
    Last Post: 09-02-2007, 02:27 AM
  5. Auto gearbox Sharan cranking problem
    By planefixer860 in forum Archive posts
    Last Post: 12-01-2006, 10:23 PM
