Thread: Touareg 3.2 V6 Petrol Hunting
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Touareg 3.2 V6 Petrol Hunting
    Quote Originally Posted by kenney View Post
    Hi The coils have a couple of things in common. ohm the earth contacts on the 4 pin connectors on the coils. Contact 1 brown on green wire and contact 2 a brown wire,these should be earthed.Have you a 12v reading on contact 3 on all 3 coils.If you have a diode lamp check first on the cyls that are firing, contact 4 and compare this with the signals on contact 4 of the dead coils.Can it be possible all three coils are buggerd.Have you had the multistick contact off the ECU,you have a possibily there.You have a wiring diagram check the voltage in to the ECU from both relays although i dont think that is the problem.
    I have swapped the coils around and that is not the problem. Same thing happens when i swap over the 3 coils with cylinders 1,2,3. The vag com is telling me that fuel injectors 4,5,6 are shorted to earth but i have checked the old fashioned way and there is no spark at the ignition coils for these cylinders. On the flow chart i can see that the multitronic system controls cylinders 1,2,3 sepratally from 4,5,6. I will check with my meter tomorrow to see if a 12v signal is present but i dont think there wil be. I have not touched the ECU. I have pulled out relay 53 and the car ran the same then pulled out relay 167 and the car would not turn over.
  2. Re: Touareg 3.2 V6 Petrol Hunting
    I have to ask you this it, might be stupid, but do you know which cyl is which?I have been wrecking my brain trying to find a solution to your problem.I was thinking what if the fault with the injectors is telling the ECU that there is a short,and the ECU is disconnecting the signals to the coils??????????????????what do you think.
  3. Re: Touareg 3.2 V6 Petrol Hunting
    Cylinder 6 is at the bulk head. I have been thinking to. I think that the ECU has stopped all signal to the 3 cylinders because of the original damage to number 6 ignition coil? This problem only started when i removed the damaged coil from number 6. If thats the case, how do i reset the ECU? Nothing on vag com, can i disconect the battery? Just seems strange that all this happened after i removed a damaged coil from number 6 cylinder. The original vag com message was number 6 cylinder miss firing. Going to try testing contact 4 tomorrow. What do you think?
  4. Re: Touareg 3.2 V6 Petrol Hunting
    Hi As well i asked you send your e-mail address and i will send you a diagram of the cyls
  5. Re: Touareg 3.2 V6 Petrol Hunting
    Hi Kenny i have sent my address to you. Do the diagrams differ from the VW workshop manual? Got VW's group complete work shop software on my lap top.
  6. Re: Touareg 3.2 V6 Petrol Hunting
    Quote Originally Posted by bigun1972 View Post
    Is there any chance the ECU may be knackered?
  7. Re: Touareg 3.2 V6 Petrol Hunting
    #17
    Hi Kenny, looks like the ECU is faulty. Took it around my mates garage and they were the first words out of his gob. Going to test it to be sure. Any ideas on repair or replacement prices? Thanks for your help it was most welcome.
  1. mark 2 golf hunting
    By shooey88 in forum Golf MK2 - 1984 - 1992
    Last Post: 29-05-2008, 06:05 PM
  2. 2000 TDi SE Tiptronic intermittent hunting
    By Audidothat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 02:43 PM
  3. 2.6 V6 hunting problem
    By andy wood in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 26-01-2008, 04:39 PM
  4. Pinking hunting and random rev increases
    By seawall in forum 100 - 200 - Turbo - 100 S4
    Last Post: 20-09-2007, 06:54 PM
