Thread: No water at rear wash wipe - how to gain access
  1. No water at rear wash wipe - how to gain access
    My Golf Gti 2.0 8v Mk4 rear wash doesnt work - wiper operates - no water. There are stains on the headlining from what is probably the wash fluid leak - not the headlining itself but the piece descending from the headlining ( passenger side rear) to the parcel shelf. I have heard the pipes disconnect - how do I get in to find the leak - cant see how to remove the headlining or rear hatch trim to get in and have a look?
  2. Re: No water at rear wash wipe - how to gain access
    nottinghamshire
    haynes manual reads
    the headlining is clipped to the roof and can be withdrawn only once all the fitting such as the handles sun visor sunroof and relayed upper trim panels have been removed and the door tailgate and sunroof apeture sealing strips have been prised clear
    also reads:
    note that the headlining removal requires considerable skill and experience if it is to be carried out without damage and is therfore best entrusted to an expert
    good luck
  3. Re: No water at rear wash wipe - how to gain access
    Sounds like one to avoid - knowing my luck I would cause more damage than its worth!
    Thanks anyway
  4. Re: No water at rear wash wipe - how to gain access
    Coventry
    there is lots on this subject on this forum. do a search for rear wash wipe or similar and you should find your answer with some reading.
  5. Re: No water at rear wash wipe - how to gain access
    Mar 2007
    coventry
    deff not for a novice small garage cheaper price
    no matter how you try you always come back to what you first started
  6. Re: No water at rear wash wipe - how to gain access
    Aug 2007
    Quote Originally Posted by golf tdi 02 View Post
    Hello Ian,
    Not to fear, just need a steady extra helping hand and a dry afternoon. I had a pretty similar issue going on with my golf. Windscreen washer fluid leaking into the boot etc.
    I wrote down what I managed to achieve in the thread below. Hope it helps as it could save you a bit of cash down the line.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=25515
    Josh
  1. Audi A4 Avant Rear Wash Wipe
    By dava in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2008, 10:00 PM
  2. Rear Wash Wipe Tubing
    By s4k1b in forum Golf MK4 - 1999 - 2004
    Last Post: 12-02-2008, 05:09 PM
  3. Rear Wash Wipe delay
    By PopDorset in forum Touran - Sharan - Caravelle
    Last Post: 27-10-2006, 09:29 PM
  4. rear wash wipe trouble
    By gareth in forum Passat - Archive Topics
    Last Post: 08-09-2006, 02:05 PM
  5. Sharan rear wash/wipe problem
    By gazmac in forum Archive posts
    Last Post: 13-02-2006, 08:40 PM
