Thread: mk4 gt tdi 130 - Over cooling
Results 1 to 10 of 10
  1. mk4 gt tdi 130 - Over cooling
    My car seems to take ages to warm up, even 30 mins constant driving and the needle can be stuck at 70ish, push it a little and it will sit at 90.
    So far i have done the following:
    Change thermostat + o ring
    Change coolant temp sender
    Could my fan control switch be gone?
    Also i notice if i sit at the lights or idle for a while the temp will start to drop from 90 for example, down to 70.. it does this in the space of around 5-10mins idle.
    Anyone have any ideas? im really clueless here, its annoying when it takes so long to get some proper warm air from vents!
    Jay
  2. Re: mk4 gt tdi 130 - Over cooling
    dazzer Guest
    hello there,try getting ur climate control plug in and have it diagnosed. your climate control controls the fans.cheers
  3. Re: mk4 gt tdi 130 - Over cooling
    the climate control unit controls the radiator fan???
    Jay
  4. Re: mk4 gt tdi 130 - Over cooling
    dazzer Guest
    try putting ur climate control on econ mode,while running the engine,the fans should be off.put it onto auto,the fans should be on.try keeping the climate control on econ mode and the temparture on 22 c,have the flaps on the window and the feet,try that, after 20 mins the engine should be up to normal working temp,try thatcheers
  5. Re: mk4 gt tdi 130 - Over cooling
    Chester-le-Street, United Kingdom
    Quote Originally Posted by dazzer View Post
    hi lads,think you may be talking at crossed purposes here.
    jay tends to think radiator fan,dazzer is thinking heater/ac fan.
    you may be right jay, but i would have thought that you would have been able to hear the rad fan running.
    i could be a million miles away,but no hot water to heater,erratic temp on gauge,would have me thinking water pump impellor?
    good luck,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  6. Re: mk4 gt tdi 130 - Over cooling
    stewey i think your right there, dazzer thinks im going on about the interior fan, which im not, i just want my "engine temperaure" to be constant and normal.
    regarding the fan impellor, surel a damaged impellor would cause the car to over heat?
    ive got g12 coolant, new thermostat, and new coolant temp sensor and still the engine stays between 70-80. only hits the middle if its on a long journey and engine constantly kept going. if im at the lights or idle the engine for a few minutes, the temp will start to drop.
    apart from the coolant temp sensor which other instruments are used to control the radiator fan? because logically speaking the only thing that can cool an engine is the radiator fan.
    Jay
  7. Re: mk4 gt tdi 130 - Over cooling
    May 2007
    I had the same problem, i did everything you done, i changed the thermostat, i had the sensors checked, water pump checked, at my local gargage, then my local garage sent it to vw at there expence and they found nothing wrong, so my garage changed the thermostat again at there expence and problem solved, are you sure it is not just your temp gauge on the dash playing up.
  8. Re: mk4 gt tdi 130 - Over cooling
    the gauge is deffo not playing up, as the hot air from the vents isnt as hot when the gauge drops.
  9. Re: mk4 gt tdi 130 - Over cooling
    May 2007
    The only thing in your engine that regulates the flow of hot water is the thermostat, maybe the wrong one was put in or it was damaged.
  10. Re: mk4 gt tdi 130 - Over cooling
    Quote Originally Posted by v6dub View Post
    i would go along with that. i have never seen one of these thermostats but apparently they are like nothing we "old'ens" have seen before, and i believe
    that they have to be fitted "just so" because of some sort of "reaction dowel"
    or similar. sounds as if it may be quite easy to get the installation wrong,sending the coolant through the radiator before it has reached opening temperature.
    as regards the water pump impellor,if it was damaged,loose or erroded it would prevent normal circulation,with little going to the far reaches of the system,the heater,but yes,you are right,it would usually overheat.
    4th cog,--two to go
  1. electric cooling fan
    By lolly in forum Golf MK3 - 1993 - 1999
    Last Post: 27-03-2008, 05:43 PM
  2. cooling 2.5 tdi t4
    By alfiboy in forum The Commercial Range
    Last Post: 05-03-2008, 10:20 PM
  3. A3 Cooling Fan Problem
    By MOTOW in forum Audi A3 - Archive Topics
    Last Post: 10-10-2007, 09:05 PM
  4. Cooling problem
    By RichKi in forum Audi A3 - Archive Topics
    Last Post: 07-09-2007, 09:00 AM
  5. cooling fan
    By mike d in forum The Commercial Range
    Last Post: 02-07-2007, 11:47 AM
