Thread: Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
  1. Question Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
    Hi all,
    I have an 02 A4 Quattro tdi 2.5 with sensors on both bumpers, had the car for 2.5 years and never had a problem, for the past 6 weeks when i engage the sensors (through the button or reverse gear) it senses for 3 seconds then goes into a constnt beep and flashing light until it is cancelled or i drive forward. It is definately not sensing as i have parked it in various positions at various proximities from objects. I checked to make sure they were clean and now i am out of ideas. Any one with some wise words on the matter?
  2. Re: Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
    Southern County Softy
    20 Post(s)
    get the car scanned for faults with a VagCom
    A4 2.5 tdi QS (mapped)
  3. Re: Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
    Is the VagCom only available at Audi Garages?How much does this scan cost roughly?
  4. Re: Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
    20 Post(s)
    have a look in the Vagcom forum for someone near you who will scan the car.
    The beeping your getting is to tell you that a fault is present, with a scan
    hopefully this will tell you which sensor is faulty.
  5. Re: Sensors on A4 Quattro 2.5 tdi Not Working, Any advice?
    sounds like a good plan, will give it a try. thanks
  1. A4 TDI quattro advice...
    By Johntheboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2008, 08:52 PM
  2. Considering a 1.9 Tdi Quattro Avant - advice?
    By gorillamonsoon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-04-2008, 08:23 PM
  3. Indicator Wing Mirror Not Working - Advice Required.
    By RickT in forum Golf MK5 - 2004 - 2009
    Last Post: 03-04-2008, 11:58 PM
  4. A4 1.9TDI Quattro Advice
    By MG Rob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2007, 12:47 PM
  5. Advice needed..Indicaters not working 2002 Golf
    By kennyb in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-05-2007, 07:32 PM
