Thread: Audi A6 1.9 tdi '04, EGR valve fault code.
  1. Audi A6 1.9 tdi '04, EGR valve fault code.
    Dec 2006
    Just bought my new car from a dealer, (not audi). The garage is quite a distance away from me so they approved a local audi specialist. They are not up holding the 6 months warrenty they sold me the car with so i am going to pay for the repairs and then pursue them for the money. Luckily the credit card company are on my side.
    Anyway the problem is:
    The engine emissions warning light appeared on the dash. Had a diagnostic test, which brought up the EGR valve. 1st of all the garage cleaned it out, i took it away and then it came straight back on. They have now changed the EGR valve.
    The light has now re appeared. I am getting concerned that it could be a bigger problem.
    I have spoken to audi's and they are very helpful!!
    They said the car had a retro fit (by audi) air filter fitted by the catalyst???
    He advise that i take it into them for them to clean and re-calibrate??
    How can he re-calibrate a filter?? Or it could be the lambda probe.
    Can anyone shed some light on this matter?
    Car drives absolutly perfect, although i think the mpg has got worse since the problem has been on the car.
    Thanks mike
    Dec 2006
    Chelmsford, Essex
    Quote Originally Posted by mike audi a6 View Post
    Thanks mike
    Hello Mike,
    I have replied to your private message, but before reading this thread.
    Audi A6 1.9 TDi 04 - May be fitted with a partical filter, its function is to remove and store soot from the exhaust. There is an adaption proceedure for measuring the soot levels and calibration if required. Normally there is no need to calibrate unless the filter is changed. Maybe this was carried out incorrectly or not at all when it was last replaced.
    EGR faults do occure due to excessive carbon build up, but make sure all vacuum pipes & connections are in good order and that all related electrical connections are clean & sucure before replacing any parts, it's possible for vacuum leaks to trick the ECU into thinking it needs to open the EGR valve.
    I have also had faulty Mass Air Meters triggering off EGR related fault codes. Faulty Mass Air Meters do not generally trigger a fault code of their own, but do cause other faults relative to the intake and combustion process.
    I hope this is of use to you.
    Rob
  1. Fault code
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 08:41 PM
  2. Fault code reader
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 10:31 AM
  3. fault code reset?
    By JELLYBEAN in forum Archive posts
    Last Post: 07-02-2007, 11:30 PM
  4. MK 3 Gti 16v Fault Code - ABS Problem
    By dravidham in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
  5. Fault Code 058F - Help!
    By Nuggs in forum Chat - Completely Off Topic
    Last Post: 24-04-2006, 02:58 PM
