Thread: Oil light flashing
Results 1 to 10 of 13
  1. Oil light flashing
    hey guys,
    On my 2001 golf tdi when i start the engine the oil light flashes for about 10 senconds, then stops. It only flashes when i start the car not when i'm driving or anything else.
    any clues anyone?
    thanks
  2. Re: Oil light flashing
    134 Post(s)
    2015 Post(s)
    Does the beeper sound?
  3. Re: Oil light flashing
    no, just a flashing light??
  4. Re: Oil light flashing
    i have had the same problem before on my polo where the oil sensor was on its way out
  5. Re: Oil light flashing
    134 Post(s)
    2015 Post(s)
    Yes, that’s what I think. I would get the instruments scanned for codes.
  6. Re: Oil light flashing
    ok thanks guys, when i first turn the ignition on, the oil light comes on red for a couple ofr seconds (not flashing though) then it changes colour to yellow and starts, for about 10 secondsish.
    so the scanning is that done with vag-com? how easy is it to change the oil sensor?
    thanks
  7. Re: Oil light flashing
    134 Post(s)
    2015 Post(s)
    I presume you have checked the oil level, yellow is level warning. When you open the bonnet, does the bonnet open symbol on the dash illuminate?
  8. Re: Oil light flashing
    oil level is fine. never looked at the dash when the bonnet is open, but will have a look later and let you know, chearse cracher
  9. Re: Oil light flashing
    hey, checked last night when i open the bonnet no light comes on, looked in the manual, i dont think a light for this exiscts! ??
  10. Re: Oil light flashing
    134 Post(s)
    2015 Post(s)
    It has a bonnet catch contains a switch, component F266, part number 1J0 953 236 B at £21.69 from VW. This tells the instrument pack that the bonnet has been opened but not all have a warning lamp. If this signal is not received, the instrument pack will not reset the oil level warning.
  1. oil light keeps flashing...
    By sj30 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2008, 09:15 PM
  2. A6 Yellow ABS Light And Flashing Red Brake Light
    By mikekirchner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-01-2008, 08:15 PM
  3. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  4. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2007, 06:02 PM
  5. flashing oil light
    By arfon in forum Audi A4 - Archive Topics
    Last Post: 27-04-2007, 12:23 PM
