Thread: noisy running
  1. noisy running
    Dec 2006
    Hello, I've got a '93 1.6 tdi passat estate. Runs great since I got it a year or so ago.But there is a whirring noise that gets louder the faster u go. It got pretty loud on the motorway recently but the noise reduced when pulling in after over taking.Noise altered on different road surface.Looked at brakes,discs and bearings seems fine.
    Any ideas?
    london/ UK
    Suggest changing your wheel bearings as they might be dry/worn. Also see if the noise stops when you press the brake peddal while driving in a straight line - worn front wheel bearings.
    Dec 2006
    Quote Originally Posted by adamss24 View Post
    Thanks for the reply, I'll try it. i did check the bearings but there wasn't any movement in the wheel, perhaps if its dry this wouldn't be the case.
    I hope your right.
    thanks
    Dec 2006
    Thanks. replace one rear bearing and noise gone, have to do the other side now.
  1. Noisy air con
    By blakey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2007, 04:54 PM
  2. Noisy Exhaust!!!
    By rottenronnie in forum Passat - Archive Topics
    Last Post: 30-03-2007, 07:45 AM
  3. Noisy aircon??
    By Mike McKinstry in forum Passat - Archive Topics
    Last Post: 14-03-2007, 09:51 AM
  4. Noisy AC
    By andywell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-03-2007, 06:15 PM
  5. Noisy Climatronic
    By Timbo in forum Archive posts
    Last Post: 31-10-2006, 10:11 AM
